February 17, 2023, 14:14 |
Couple Moody with OpenFOAM v1906
Aaryan
Rep Power: 3 |
Hello everyone,
I have tried to couple the OpenFOAMv1906 with Moody. i followed all the steps provided in moodyAPI master by Johannes Palm. I am getting the error FOAM FATAL ERROR: [2] Unknown solver type rigidBodyMotion I also attached the log.interFoam file i have attached all the corresponding file in which i have made the changes. I have followed all these steps provided in the folder moodyAPI 1.0 In rigidBodyDynamics library: a) In rigidBodyModel/rigidBodyModel.H //-Remove const specifier for applyRestraints() method b) In rigidBodyModel/forwardDynamics.C //-Remove const specifier for applyRestraints() method 1.1. Remove const requirement on restrain function. a) In restraints/restrain.H, change existing restrain method to: //- Accumulate the retraint internal joint forces into the tau field and // external forces into the fx field virtual void restrain ( scalarField& tau, Field<spatialVector>& fx ) const {}; //- Accumulate the retraint internal joint forces into the tau field and // external forces into the fx field virtual void restrain ( scalarField& tau, Field<spatialVector>& fx ) { restrain(tau, fx); } //- Test to recompile library -// 1.2. Install moodyR restraint: a) Add moodyR.C and moodyR.H to the rigidBodyDynamics/restraints folder. b) Add moodyR.C to the file list in Make/files. c) Change the compiled library name and location at the end of Make/files to: LIB = $(FOAM_USER_LIBBIN)/libmoodyRigidBodyDynamics c) Change Make/options to: (use your own moody installation path) (My experience is that the -rpath is sometimes needed on computer clusters to find the library at runtime) EXE_INC = \ -I$(HOME)/moody/moody-2.0.0-Linux/include LIB_LIBS = \ -L$(HOME)/moody/moody-2.0.0-Linux/lib \ -Wl,-rpath=$(HOME)/moody/moody-2.0.0-Linux/lib \ -lmoody //- Test to compile moodyRigidBodyDynamics library -// 1.3 Move to rigidBodyMeshMotion library. Refer to the new moodyRigidBodyDynamics library instead. Change Make/options to: EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/fileFormats/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I../rigidBodyDynamics/lnInclude \ -I$(LIB_SRC)/functionObjects/forces/lnInclude \ -I$(LIB_SRC)/dynamicMesh/lnInclude LIB_LIBS = \ -lfiniteVolume \ -lmeshTools \ -lmoodyRigidBodyDynamics \ -lforces \ -ldynamicMesh 1.4 Finally change Make/files to: rigidBodyMeshMotion/rigidBodyMeshMotion.C rigidBodyMeshMotionSolver/rigidBodyMeshMotionSolver.C LIB = $(FOAM_USER_LIBBIN)/libmoodyRigidBodyMeshMotion //- Test to compile moodyRigidBodyMeshMotion library -// Kindly guide me |
couple of1906 & moody, moody, openfoamv1906 |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 07:15 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
