Achieving Angular Velocity in a 3D Cylinder Simulation
Old   February 9, 2023, 21:41
Red face Achieving Angular Velocity in a 3D Cylinder Simulation
Niyas
niyas is on a distinguished road
In this post, I will be discussing the method for obtaining angular velocity in a cylinder in a 3D numerical simulation. I am utilizing Fortran-based in-house coding to simulate a bar and a cylinder. The simulation for the bar (referred to as Figure-1) was successful and I had no issues. For the bar, I used the following initial velocity conditions: a positive 'u' velocity along the x-axis, a 'v' velocity of zero along the y-axis, and a 'w' velocity of zero along the z-axis. This resulted in a streamlined pattern, calculated using √(u^2+v^2+w^2 ), as shown in Figure-2.
Regarding the 3D cylinder simulation (Figure-3), using the same procedure for initializing the velocities did not produce the desired result, as seen in Figure-4. I want to achieve a positive angular velocity within the cylinder, but I am unsure how to specify the 'u' and 'v' velocities to achieve this. I know the 'w' velocity must be zero, but I need a solution for the 'u' and 'v' velocities that will result in the desired angular velocity, as shown in Figure-5.
Regards,
Niyas
niyas is offline   Reply With Quote
Old   February 10, 2023, 05:12
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by niyas View Post
You may want to look at this page and consider the function ATAN2 in Fortran.
In the end, your cartesian velocity components u and v at given x and y where you know the tangential velocity v_\theta are given by:
\begin{split}
u = -v_\theta \sin{\left[ATAN2\left(y,x\right)\right]} \\
v =  v_\theta \cos{\left[ATAN2\left(y,x\right)\right]}
\end{split}
sbaffini is offline   Reply With Quote
Old   February 12, 2023, 22:57
Niyas
@sbaffini, the command you suggested was very effective (Figure-1). Thank you!!
Is it possible to set the 'u' and 'v' velocities as constant within the cylinder?
At present, the 'u-velocity' (Figure-2) and 'v-velocity' (Figure-3) have varying values within the cylinder.
Is there a method to make them constant?
I aim to maintain a steady cartesian flow-field velocities within the cylinder.
Regards,
Niyas
Old   February 13, 2023, 05:39
sbaffini's Avatar
Paolo Lampitella
I probably don't understand. How can the two velocities be constant AND parallel to the cylinder surface at the same time?
You kind of made a clear picture of the streamlines you wanted, and those can't be achieved by constant u and v.
Old   February 13, 2023, 05:56
Niyas
"In a 3D bar, there is an initial condition of a positive uniform velocity of 5.5 m/s (u = 5.5 m/s and v = 0) flowing from one end to the other.
Similarly, I need to create a uniform velocity field within a cylinder as an initial condition. Instead of using linear velocity (u), should I use angular velocity (omega)?
Omega is calculated as the tangential velocity divided by the radius.
If I opt for omega, then I won't have 'u', 'v', and 'w'. Instead, I'll only have 'omega' and 'w'. Will this necessitate a modification of the entire code structure, including the governing equations, etc.?
My aim is to replicate the results obtained in a 3D bar in a 3D cylinder. Initially, I thought I could simply change the geometry from a bar to a cylinder to obtain the same results. Will this approach work?
Regards,
Niyas
Old   February 13, 2023, 06:17
sbaffini's Avatar
Paolo Lampitella
Nothing of this really helps.
Flow in your geometry can either be fully tangential with no axial component, like in my first answer, or only axial with no tangential component (in this case your velocity will have just the z component of your choice) or both (you combine my first answer with your preferred z component).
Any other initialization will give you a velocity going into or out of walls.
If you have a reference work you want to replicate, it is better if you just put a link here of the whole work
Old   February 13, 2023, 21:42
Niyas
I appreciate your valuable insights and thank you for taking the time to share them.
If it's not too much trouble, would you kindly provide me with your email address? I'd like to share more details with you about the project. Alternatively, if you prefer, you could simply send a quick "hi" to my email address at niyasdeen.aero@gmail.com.
Regards,
Niyas
Old   February 14, 2023, 05:50
sbaffini's Avatar
Paolo Lampitella
Don't take me wrong, but I can't. I mean, my email is kind of everywhere and you can pick it up and just send an email, but don't expect an answer anytime soon or an answer at all. I usually make exceptions only when the topic is very specific and I am kind of into the argument myself, but this is not the case.
My suggestion is to clearly state your problem here, what you want to do, how, where you have problems and which problems. Then anyone, including me, is here to help.
But, at least personally, I'm willing to help when my contribution is around 10% at most, possibly less. I want the freedom to just drop any correspondence when I feel that there aren't the conditions anymore to help. If you write to me, I still have that freedom of course, but then I look like an a..hole, which is not nice in any case.
In your specific case, you should better describe your problem, in my opinion. But maybe someone else will understand, which is your main advantage from keeping this thing here instead of private email.
Old   February 15, 2023, 22:53
Niyas
Thank you for sharing your thoughts. I will take your suggestions into consideration and provide more details about my problem in the future.
Additionally, I wanted to let you know that I'm planning to move forward with no velocity as an initial condition, as you mentioned. However, I've bumped into another issue that I will create in a separate thread. Thank you again for your help and advice.
Regards,
Niyas
angular velocity, cylinder, numerical simulation, streamline pattern
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
How to extract Angular Velocity from Simulation? David12 FLUENT 3 August 14, 2020 01:26
Velocity Sampling in parallel simulation Torii_Nagi Fluent UDF and Scheme Programming 1 July 20, 2020 02:29
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 10:45
export velocity profile and import in an other simulation as initial condition FFD STAR-CCM+ 4 February 5, 2016 08:27
