Why do we need deferred correction when it can't help yield a valid result? |
February 5, 2023, 20:36 |
#21 | |
Jasmine Feng
Rep Power: 3 |
February 5, 2023, 20:45 |
#22 | |
Jasmine Feng
Rep Power: 3 |
Pe=ρ*u*Δx/Γ So Pe > 0 denotes u>0 and Pe<0 denotes u<0, but the diffusive coefficient Γ keeps the same. Yeah, this is a 1D steady convection-diffusion exercise without any source term. But from Versteeg and Malalasekera's textbook instead of Ferziger et al's. |
February 6, 2023, 00:41 |
#23 | |
Arjun
Rep Power: 34 |
Yes. If you got stable and good results with CD on those peclet numbers you would have broken known mathematics. When we use unbounded CD all the solvers produce wiggle in solution or just diverge. This is why we have bounded central differencing schemes in solvers. This scheme blends enough upwind scheme to the make it stable. Last edited by arjun; February 6, 2023 at 03:33. |
February 6, 2023, 03:46 |
Ceribena Noche
#24 |
ceribenanoche
Check out the latest Ceribena Noche results as https://ceribenanoche.com/ we provide the latest Ceribena Noche results daily.
deferred correction, iterative method |
error to check simulation result: could not find valid OpenFOAM mesh | xiaoyoyo | OpenFOAM | 5 | May 18, 2017 12:38 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Timestep and Pressure Correction Relationship in SIMPLE | rks171 | Main CFD Forum | 23 | May 4, 2012 02:04 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
