January 27, 2023, 07:07 |
Inspire Extrude TDB_Batch_Failed
Oguzhan
Hey,
I am getting the attached error while performing metal extrusion die analysis. There is no problem when performing flow analysis, but it comes out in the die. What is the cause of the problem? How can I solve it? Thanks. |
altair, aluminum extrusion, fluent, hyperxtrude, inspire extrude |
[GMSH] extrude rotation from arbitrary OpenCASCADE center | crubio.abujas | Mesh Generation & Pre-Processing | 0 | February 2, 2022 13:44 |
Can't use the Extrude Translation | lamagavoragine | Pointwise & Gridgen | 3 | March 11, 2019 23:05 |
[Gmsh] 3D mesh using transfinite surface + extrude with layer? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 0 | July 5, 2016 02:26 |
[ICEM] How can I extrude a 2D Hexa Mesh along a center curve? | Daniel C | ANSYS Meshing & Geometry | 21 | November 9, 2012 09:10 |
[Gmsh] Cannot get the right mesh from gmsh | JinBiao | OpenFOAM Meshing & Mesh Conversion | 2 | August 31, 2010 04:51 |
