Simulating compressible flows
Old   January 20, 2023, 08:35
Default Simulating compressible flows
Haise_Sasaki is on a distinguished road
So I am trying to validate my drag calculations for a projectile travelling at supersonic speeds, let's say Mach 3. What I am worried about is how Fluent is calculating density (I have selected Ideal gas), since density changes with altitude. How can i get Fluent to take the density of air at that altitude while simultaneously simulating a compressible flow. Any help is much appreciated
Haise_Sasaki is offline   Reply With Quote
Old   January 20, 2023, 10:05
Hayden Arceneaux
haydena is on a distinguished road
I think you have a fundamental misunderstanding of what happens to density in a compressible flow field. Density at specific altitudes will be the density at the inflow/farfield boundaries. I.E. the density in front of the bow shock will be atmospheric density.
The ideal gas law is the equation of state for the gas. It doesn't dictate the inflow density condition, which should be specified at the boundary.
If you don't have this fundamental understanding you need to do more research into CFD and probably more tutorials for Fluent. It is VERY easy to get non-physical results so you must be aware of what every input you specify does.
haydena is offline   Reply With Quote
Old   January 21, 2023, 00:45
Sure I get that, and that's exactly what i am worried about. If i give constant density at inflow, the simulation does not converge. When you select ideal gas you don't get to dictate the density instead fluent 'guesses' it for you using the ideal gas law based on the operating pressure given. This is my understanding based on the research I have done on Fluent. Please correct me if i am wrong and how i can go about fixing this.
Old   January 21, 2023, 02:27
I think i got your point now. I have figured it out. Thanks for our help.
Old   January 23, 2023, 02:56
xiaolong li
xiaolong.li is on a distinguished road
Hi, i also meet a same problem. Could you please give me some suggestions, thanks a lot!
My project is to simulate the flow around the hypersonic missiles, including heat and flow, the inflow mach number is 15, attitude is 40km.
I did this by fluent, but i dont know how to set the boundary condions. Hope you can help me, thanks again.
xiaolong.li is offline   Reply With Quote
#cfd, #compressibleflow #fluent
[rhoCentralFoam] simulating compressible inviscid flow Yuval OpenFOAM Running, Solving & CFD 2 January 27, 2016 22:33
Why is the side slip option only for compressible flows denzell SU2 1 March 10, 2015 20:26
Reference parameter specification in .cfg file for compressible viscous flows SumanVajjala SU2 1 June 26, 2014 00:58
Low Mach Number Compressible Multiphase Flows DarrenC CFX 10 May 26, 2014 09:52
compressible flows shuo Main CFD Forum 1 August 24, 2007 12:59
