impeller of pump
Old   August 10, 2000, 00:41
Default impeller of pump
sameer mohrir
What will happen to flow complexity if number of impellers on pump shaft are increased.
Old   August 10, 2000, 01:26
Default Re: impeller of pump
John C. Chien
(1).It will first increase the efficiency. (2). Then, the blade thickness will take away the available space for the flow. The mass flow will be reduced. (3). Even when the blade thickness is reduced, the total surface area will increase with the number of blades, and the loss will also increase. (4). Eventually, you don't have space left for the flow. (I think, 13 is a good number. 19 is upper limit. 3 or 5 is fine.)
Old   August 24, 2000, 08:09
Daniel Jaeggi
In terms of flow features, increasing the number of blades reduce the blade loading and the slip factor.
In other words, the velocity distribution across the blade passage is more uniform. This has two effects.
Firstly, the chance of separation on the pressure surface is reduced (this comes from an inviscid analysis of the velocity distribution across the passage).
Secondly, as the Kutta condition is enforced at the end of the blade, similar velocities either side of the blade measn the resulting adverse pressure gradient is reduced. The boudary layers will be thinner and more likely to stay attached.
Hope this helps.
dan
Old   August 24, 2000, 11:04
sameer mohrir
Hi dan
If possible can you clarify this
"In terms of flow features, increasing the number of blades reduce the blade loading and the slip factor".
in detail
regards
Old   August 24, 2000, 21:44
John C. Chien
(1). He is talking about the condition which deviates from the idealized inviscid solution model. (in most cases, it is 2-D inviscid, with infinite number of blades having zero thickness. (2). In other words, with finite number of blades, the flow at the exit, or the trailing edge will no longer follow the geometry of the blade. (slip factor).(3). You will have to study the pump theory to understand it.
Old   August 25, 2000, 05:18
Daniel Jaeggi
Hi sameer,
Hope this helps!
In the impeller, by fixing the mass flow rate, the rotaional speed and the inlet and exit angles, you fix the amout of work done. This comes direstly from Euler's work equation which is derived from the momentum equation applied to a control volume round the blade.
This work has to come from somewhere - the somewhere being an average force on the blades * distance moved. The distance moved is fixed (from rotational speed) and so is the energy. So the force provided by ALL the blades is fixed. Increase the number of blades and you reduce the individual force on each blade.
Where does this force come from? As ever with fluids - pressure. In order to get a pressure difference on either side of the blade, the velocities on either side must be different. So across the blade passage, the velocity must also vary.
The slip factor is a measure of the variation in flow angle at exit across the passage. I forget the exact definition - look in any decent turbomachine text and you should find it. But the slip factor has the effect of reducing the effective exit angle.
dan
Old   August 25, 2000, 06:51
sameer mohrir
Hi dan
This will help. Thanks
sameer
Old   August 25, 2000, 10:26
Daniel Jaeggi
A final note!!
There is an excellent treatment of centrifugal impellers in "Compressor Aerodynamics" by N Cumpsty.
how to extract the components of radial and tangential velocities from pump impeller renyun0511 OpenFOAM Running, Solving & CFD 3 October 31, 2022 10:31
Centrifugal Pump Impeller design invincible328 Main CFD Forum 27 September 21, 2014 11:59
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 04:07
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
boundary condition impeller centrifugal pump mino2006 FLUENT 2 December 28, 2006 19:07
