The peak heat isn't located at the stagnation point of a 2D cylinder
Old   January 11, 2023, 10:27
Default The peak heat isn't located at the stagnation point of a 2D cylinder
Dengke Li
Iniesta8 is on a distinguished road
Hello, everyone
Recently, I found that the heat flux results of a 2D laminar cylinder are mismatched with the fact. As we all know, for a hypersonic flow over a cylinder, the peak heat flux is located at the stagnation point. The true distribution of heat flux is like this But when I use some software or CFD codes to do the simulation, the result is that the peak heat flux is always a bit deviation to the stagnation point. The figure is attached. The grid is 2D and the height of the first layer is 1e-6m.
I don't know why the CFD results are wrong, can anyone give me some advice?
Many thanks!!!
Iniesta8 is offline   Reply With Quote
Old   January 12, 2023, 05:15
Will Kernkamp
wkernkamp is on a distinguished road
The stagnation point will have the highest temperature if the wall has no heat flux. I suppose you gave the wall a fixed temperature. This means the wall is going to cool the flow near the stagnation point. At the stagnation point, there is very little fluid movement, so the cooling is more effective there relative to adjacent locations.
wkernkamp is offline   Reply With Quote
Old   January 12, 2023, 05:37
Dengke Li
Thanks for your reply,
Yes, I used an isothermal wall boundary for the cylinder wall. But in theories, the temperature gradient of the stagnation point is the highest and many experimental results prove that the stagnation point has a maximum heat flux. Here you can see a comparison of experimental and CFD results. experiment.JPG
Old   January 18, 2023, 08:40
Dengke Li
Originally Posted by sellardsh View Post
I think you will be able to find the answer to this question using this link. The article exclusively deals with the Simulation of Conjugate Heat Transfer in Thermal Processes with Open Source CFD
That is not a link to the article!!! And my case is a pure fluid flow without the simulation of heat transfer in solid.
Old   January 18, 2023, 10:46
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
What code did you use to get those results? Is it an immersed boundary code? If in house code, what method did you use?
Btw, you are right, higher heat flux should be at stagnation point for your fixed temperature bc. But the problem I see here is slightly different. The max heat flux seems shifted because of those oscillations that just seem to get worst at the stagnation point.
Give more details and we will try to help
sbaffini is offline   Reply With Quote
Old   January 18, 2023, 10:47
sbaffini's Avatar
Paolo Lampitella
Also, I see you are postprocessing results in paraview? How were they written to file and processed?
Old   January 18, 2023, 21:33
Dengke Li
Hi
Thanks for your reply. The code I used is Hy2Foam, which is based on the OpenFoam framework. Now I think the reason for the unphysical result is that my mesh is not dense enough in the flow direction. But after refining the mesh, the peak heat is still located at a tiny distance from the stagnation point.
Old   January 19, 2023, 05:09
sbaffini's Avatar
Paolo Lampitella
This almost certainly excludes postprocessing issues and also the code is not IB. Have you maybe done some of the tutorials of the code, to see if the problem is there as well?
Old   January 19, 2023, 05:37
Dengke Li
I have done some tutorials like a blunt cone. And the result is fine. This question just appears when I doing a 2D blunt body simulation. I also have done the simulation with some commercial software like fluent and CFD++. But it also needs a very dense grid to make the peak heat almost located at the stagnation point.
From my side, this mismatch with the fact can almost avoid via a very dense grid. And it will cost much more time to achieve convergence. I still want to know why it needs a so dense grid when doing 2D blunt body simulations.
Old   January 19, 2023, 07:42
Lucky
More than the peak heat not being at the center, there is the greater issue that the heat flux is not smooth anywhere. I suspect there is some c-grid shenanigans that doesn't go away no matter how you refine the mesh because the same skewed cells are messing you up every time. It doesn't happen in the tutorial because, well, you followed the tutorial instead of doing things on your own. There is a lot more amuck than the peak heat not being in the center, don't bury them under the rug.
Old   January 19, 2023, 08:08
Dengke Li
Hi
Thank you for the advice.
Yes, I know what you mean. But when I doing a sphere simulation, this mismatch will not take place. And the mesh is generated by myself. And the fluctuations always exist less or more because of the skewed cells. Could you tell me how to avoid these "c-grid shenanigans"?
heat transfer laminar, hypersonic flow
How to implement time-varying boundary conditions in an enclosed cylinder Alejandro-FA OpenFOAM Pre-Processing 0 May 14, 2020 07:29
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Conjugate Heat transfer- Heat generating cylinder & natural convection sandymech OpenFOAM Running, Solving & CFD 6 July 3, 2018 14:40
Convection heat transfer at stagnation point canonical problem MachZero Main CFD Forum 9 March 15, 2018 07:49
Volumetric Heat generation in cylinder with natural convection conjugate heat transfe sandymech OpenFOAM Running, Solving & CFD 0 August 9, 2017 19:36
