turbulent flow using PHOENICS
Old   October 10, 1998, 12:17
Default turbulent flow using PHOENICS
Abdul Hafid
Hi every body
I want to simulate a turbulent flow around axisymmetric body. Any one knows how to simulate the turbulent flow using PHOENICS
Old   October 14, 1998, 10:11
Default Re: turbulent flow using PHOENICS
Rasputin
errrr, RTFM?
Old   October 14, 1998, 11:39
Dawei Sun
I have used PHOENICS to simulate turbulent flow. BUt I really don't know what kind of thing you want to do. Develop your own model? Do you need to generate the grid?
Old   October 15, 1998, 06:44
Abdul Hafid
Hi Dawei Sun
Thank you for your response. I want to use PHOENICS shareware ver 1.5 I've downloaded from the internet. I don't know how to use Q1 file to write the turbulant part. any examples or library cases that can help?.
Old   October 16, 1998, 10:24
Abdul Aziz Jaafar
Dear Abdul Hafid
Perhaps the best example to model the axisymmetric flow by chossing the library case on pipe flow. You can also look at any library case with turbulent flow. I think the good start to select turbulent flow with mixing length turbulence model. and you can compare the result with laminar flow
A. Aziz Jaafar
Old   November 3, 1998, 12:25
Vijay Thaker
If your using ver 1.5 share ware u might able to use the beginners manu to create your model step by step. Just access your sattelite ang type :
load(menu) then press enter the menu will guide u step by step.
Thanks.
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 02:00
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 04:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 05:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 10, 2010 00:10
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 03:52
