Why does turbulence BC does not hinder convergence?
Old   December 12, 2022, 09:44
Default Why does turbulence BC not hinder convergence?
Jingchang.Shi
aerosjc is on a distinguished road
I have a question on the turbulence BC.
For example, https://su2code.github.io/tutorials/...lent_NACA0012/ gives a turbulent NACA0012 case. Normally we know that at the farfield the SA model uses Dirichlet BC nu_tilde = 3~5 nu_tilde_freestream. For refenrence, check NASA TMR page.
Using a CFD solver like SU2, we could obtain a converged solution.
The contour of nu_tilde (check the attached figure) shows that at the outflow boundary the calculated turbulence deviates from the pre-specified value (3 nu_tilde_freestream). The pre-specified nu_tilde at the outflow boundary is in the BLUE color while the calculated nu_tilde at the outflow boundary is in the white color.
So my question is: the calculated turbulence at the outflow boundary is different from the pre-specified turbulence, which means that we force a solution at the outflow boundary different from the calculated solution distribution. I think they are incompatible with each other. We force an incompatible BC but the solver still gets converged. Why?
aerosjc is offline   Reply With Quote
Old   December 12, 2022, 13:17
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by aerosjc View Post
At an outflow, by definition, you get what comes from inside the domain. So it means that you get wake values in the wake and inlet values away from the wake.
It would be a problem if this was happening at an inlet but, in that case, you would indeed experience difficulties in convergence (unless a more complex inlet method is used)
sbaffini is offline   Reply With Quote
Old   December 14, 2022, 08:05
Jingchang.Shi
After some numerical experiments, I confirm that the outflow boundary location would not affect the convergence only if the outflow boundary is placed 2 chord length away from the airfoil trailing edge. If the outflow boundary is placed at the wake region, the simulation blows up. The simulation is by SU2. This behavior seems reasonable to me. The PDE system adjusts its solution to different BC. For example, a simple equation f''=4 has the analytic solution f = 2 x^2 + a x + b. The coef a and b depend on BC. {f(1)=1, f(-1)=1} results in different solution from {f(1000)=1, f(-1000)=1}. But both allow a converged solution. In the cell-centered finite volume CFD solver, the BC is weakly coupled by a Riemann solver. A Dirichlet BC specifies the value in the ghost cell while the interior value is still calculated by the simulation. The real working value is the Riemann flux calculated based on both the interior value and the BC value.
Old   December 14, 2022, 08:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
That depends on the mathematical character of the PDE, you must differentiate the correct BCs for elliptic, parabolic, hyperbolic PDEs
FMDenaro is offline   Reply With Quote
Old   December 14, 2022, 10:21
Jingchang.Shi
Sure. I use the simple example of f''=4 because it takes a lot to discuss NS equation. We could have some feelings about how BCs of NS equation behave but it is hard to strictly give math descriptions of the behaviors.
boundary condition, convergence
In cylinder flow convergence using K omega Turbulence pary07 STAR-CCM+ 0 July 24, 2017 19:13
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity Anwer FLUENT 1 August 8, 2016 17:59
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
Convergence not with all turbulence modells Mazur FLUENT 1 January 17, 2013 05:44
Force can not converge colopolo CFX 13 October 4, 2011 23:03
