December 9, 2022, 04:15 |
parallel processers Scaling for CFD
Rishi Kumar
Rep Power: 4 |
Hi there,
I have a query regarding the scaling of parallel processors Simulation for CFD. what is the scaling law for parallel processing simulation for CFD based on domain decomposition? I have performed scaling in Openfoam, but need some validation support for it. |
December 9, 2022, 08:12 |
Lucky
Rep Power: 66 |
In many practical cases, it goes as bad as sqrt(N). If it starts to go even worse than I stopped adding additional threads and stick with sqrt(N).
December 9, 2022, 09:40 |
Alex
Rep Power: 49 |
It depends...
General recommendations for CFD hardware [WIP] You can get pretty much anything, depending on how you do your analysis. Linear scaling, superlinear scaling, scaling that could be fitted with Amdahl's law, no scaling at all. negative scaling... Probably a good idea to start with terminology. Are you interested in strong or weak scaling? Intra-node or inter-node? |
December 10, 2022, 05:37 |
Rishi Kumar
Rep Power: 4 |
December 10, 2022, 05:39 |
#5 | |
Rishi Kumar
Rep Power: 4 |
Thanks for the response |
mpi, open foam, parallel processing, validation |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
parallel scaling with sliding interfaces | laf | FLUENT | 1 | March 23, 2007 11:50 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
