Question about inviscid model in CFD software
Old   November 25, 2022, 23:20
Default Question about inviscid model in CFD software
Zheng Xiaoluan
Adorkable is on a distinguished road
Hi, hello everyone,I have a strange question.
When can the inviscid model (not potential model) be applied in CFD software? In other words, how to judge the inviscid model and turbulent model has little influence on the numerical results?
Thank you everyone!
Adorkable is offline   Reply With Quote
Old   November 26, 2022, 05:37
Sayan Bhattacharjee
aerosayan is on a distinguished road
When the simulation you're trying to do, doesn't need viscosity to give accurate results.
For example: Hypersonic flows can ignore viscosity.
Don't worry too much. Learn how to solve with viscosity. The problem you're trying to solve will most likely state if you need viscosity or not.
aerosayan is offline   Reply With Quote
Old   November 26, 2022, 05:47
Agustín Villa
agustinvo is on a distinguished road
If you are doing RANS, the turbulent stress tensor is there because of the fluctuating velocities in the advection term. Should we neglect as well the turbulence modelling?
agustinvo is offline   Reply With Quote
Old   November 26, 2022, 05:57
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thank you everyone!
Yes, strange question…
Inviscid fluid model (Euler equations) is used prevalently for potential flows and shock-waves dominated problems.
Few applications can be found for LES.
FMDenaro is offline   Reply With Quote
Old   November 27, 2022, 07:27
K
kinematic_presser is on a distinguished road
If you non-dimensionalize the Navier-Stokes equations (https://en.wikipedia.org/wiki/Non-di...okes_equations) you will see that the coefficient in front of the viscous can be written as 1/Re . (The article shows the incompressible NS, but this is true for compressible NS as well).
Therefore in order to ignore the effects of viscosity the Reynolds number should be quite large, probably a million at the very least.
kinematic_presser is offline   Reply With Quote
Old   November 27, 2022, 07:46
Just to address some further comments.
Assuming ideal flows (no viscosity, no conducibility) you disregard any type of dissipation of kinetic energy. That means you have a model for the turbulence where the energy cascate is never terminated by dissipation.
In no way that can be simulated on a finite grid since the theoretical Kolmogorov lenght is exactly zero and you can never approach a DNS.
Therefore, in any simulation you have to terminate numerically the energy cascate.
Furthermore, since you have no dissipation, you cannot suppose a statistical energy equilibrium between production and dissipation of kinetic energy to introduce a turbulence model for the closure of the equations.
In this sense, RANS is not suitable as formulation.
The Euler equations are mainly solved for flows with shock by disregarding the turbulence effects.
https://link.springer.com/chapter/10.1007/11545989_1
Zone model: CFD or analythic model? bhigahAshish Main CFD Forum 0 July 24, 2020 04:34
CFD model validation with experimental data Alsumri ANSYS 6 November 14, 2019 12:14
Validation of CFD model flow_CH Main CFD Forum 4 November 4, 2019 11:30
General question about SST turbulence model Richard Renaud CFD Freelancers 1 December 19, 2015 05:13
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
