openfoam 2206 twoPhaseEulerFoam
Old   November 25, 2022, 13:56
Default openfoam 2206 twoPhaseEulerFoam
London
CBranch171 is on a distinguished road
Hi
I am using twoPhaseEulerFoam copied from a tutorial and when I add function objects to the controlDict I get the below written out:
Duplicate entry laminar in runtime table TurbulenceModel
#0 /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x42) [0x7faa1bb25b02]
#1 /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/lib/libreactingMultiphaseSystem.so(+0x144a12) [0x7faa04655a12]
Its actually very long list of libs after this point
my function objects look like this:
functions
inletFlowPressure // pick your name
type surfaceFieldValue;
libs (fieldFunctionObjects);
fields (p);
writeControl writeTime;
writeFields no;
regionType patch;
name inlet; // put the name of your patch/outlet here
operation areaAverage;
inletFlowGas // pick your name
fields (phi);
writeFields no;
regionType patch;
operation weightedSum;
weightField alpha.gas;
inletFlowWater // pick your name
fields (phi);
writeFields no;
regionType patch;
weightField alpha.water;
outletFlowPressure // pick your name
fields (p);
writeFields no;
regionType patch;
name outlet; // put the name of your patch/outlet here
outletFlowGas // pick your name
fields (phi);
writeFields no;
regionType patch;
outletFlowWater // pick your name
fields (phi);
writeFields no;
regionType patch;
when I comment these out the error goes.
Does any one know what the problem is.
CBranch171 is offline   Reply With Quote
openfoam 2206, twophaseeuelrfoam
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
