Can Final Temperature of Hot fluid be lower than cold fluid in a heat exchanger? |
Aaditya
Rep Power: 5 ![]() |
Hello everyone,
(This is an urgent problem so please have a look at it and suggest me if you have a solution as soon as possible) I am having a trouble calculating the final temperatures of fluid in a heat exchanger. The problem is as follows: I have a heat exchanger with effectiveness of 0.67 The fluid inside the tube is water with following properties: inlet temperature: 303 K Specific heat capacity (water) = 4184 J/kg K flow rate (water)= 0.00002 m^3/sec density = 1000 kg/m³ The fluid outside is air with following properties inlet temperature: 298 K Specific heat capacity (air) = 1006.3 J/kg K flow rate (water)= 0.10372 m^3/sec density = 1.1845 kg/m^3 My approach: Cp_water = 4184 * 1000 * 0.00002 = 83.68 Cp_air = 1006.3 * 1.1845 * 0.10372 = 123.63 Q_max = Cp_min * (T_water_inlet - T_air_inlet) =83.68 * 5 Q_max = 418.4 W Actual heat flow = Q_act = Q_max * Effectiveness = 418.4* 0.67 = 280.328 W For both the fluids the difference in outlet and inlet temperatures is referred below as T_diff with _a and _w as suffix for air and water respectively T_diff = T_inlet - T_outlet Q_act = Cp_water * T_diff Thus, T_diff_w = Q_act / Cp_water = 280.328 / 83.68 = 3.35 K T_diff_a = Q_act / Cp_air = 280.328 / 123.63 = 2.267 Here as you can see the final temperature of water is 299.65 K and for air is 300.267 K. Have I made any mistake in calculations? or is this practically possible? Please help me! Thank you! |
#2 | |
Sam
Rep Power: 0 ![]() |
Erik
Rep Power: 23 ![]() |
This is possible on a counter-flow heat exchanger only.
If the two fluids are traveling the same way, then no it is not possible. With a counter flow heat exchanger, the outlet of one fluid is exchanging heat with the inlet of the other. |
heat and mass transfer, heatequation, heatexchanger, temperature calculation |
chtMultiRegionFoam speed up | qwertz | OpenFOAM Running, Solving & CFD | 8 | September 18, 2021 06:16 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
