Strange-behaviour of runge kutta schemes
Old   November 5, 2022, 19:27
Lightbulb Strange-behaviour of runge kutta schemes
Nico
Nico994396 is on a distinguished road
Dear all,
i'm developing a solver for the Compressible Euler Equations by using explicit Runge-kutta 4 scheme.
In particular, i've followed the approach of the following paper:
"On the implementation of low-dissipative Runge–Kutta projection
methods for time dependent flows using OpenFOAM" by V. Vuorinen a, ⇑ , J.-P. Keskinen a , C. Duwig b , B.J. Boersma.
Even tough i write the code ( sorry if it seems that it is not compact, but it was a test ), it seems that the method is not stable:
Indeed, i tested the solver with an atmosphere in equilibrum ( i used the potential temperature to initialize the field ), and even tough i use very small time steps, during the time evolution waves are created ( if the solver is balanced the atmosphere should remain at rest ).
You can find an image of what happens during the simulation ( the image shows that pressure-waves are created) and you'll find my solver.
If someone can give an explanation about that i will be greatfull.
Thank you.
EulerRK4Foam.C
correctBoundaryRho.H
Nico994396 is offline   Reply With Quote
euler equation, openfoam, runge kutta method, solver development
Implicit Runge Kutta Schemes for Stiff Systems backscatter OpenFOAM Programming & Development 0 April 24, 2019 01:34
rhoCentralFoam Runge Kutta Henning86 OpenFOAM Running, Solving & CFD 24 December 13, 2016 11:12
Strange behaviour when using compressibleInterFoam with constantAlphaContactAngle TobM OpenFOAM Running, Solving & CFD 2 May 11, 2016 07:34
TVD Runge Kutta 3rd order Schemes Prixy11 Main CFD Forum 0 April 20, 2015 10:17
Strange residuals behaviour xxxx Main CFD Forum 1 July 13, 2013 15:40
