November 4, 2022, 07:58 |
gmsh boundary layer mesh for channel flow
Rep Power: 4 |
I would like to mesh a periodic channel flow with structured grid using gmsh. I firstly mesh it with transfinite lines and it works but I do not succeed in keeping the first cell size to obtain y+=1 when refining the mesh: Code:
n = 50; nb_points = n; r=1.02; nb_points_centre = 26; SetFactory("OpenCASCADE"); //+ Point(1) = {0, 1/3, 0, 1.0}; //+ Point(2) = {0, 1, 0, 1.0}; //+ Point(3) = {1, 1, 0, 1.0}; //+ Point(4) = {1, 1/3, 0, 1.0}; //+ Point(11) = {1, 0.7, 0, 1.0}; //+ Point(13) = {0, 0.7, 0, 1.0}; //+ Line(1) = {4, 11}; //+ Line(2) = {11, 3}; //+ Line(4) = {1, 13}; //+ Line(5) = {13, 2}; //+ //+ Line(8) = {1, 4}; //+ Line(9) = {13, 11}; //+ Line(10) = {2, 3}; Line Loop(13) = {8, 1, -9, -4}; //+ Plane Surface(1) = {13}; //+ Line Loop(14) = {9, 2, -10, -5}; //+ Plane Surface(2) = {14}; Symmetry {0, 1, 0, -1} { Duplicata { Surface{1}; Surface{2}; } } Coherence; Transfinite Line {1, 4} = nb_points Using Progression r; Transfinite Line {10, 11} = nb_points_centre; Transfinite Line {8,9} = 1; Transfinite Line {9, 12} = 1; Transfinite Line {17, 18} = nb_points_centre; //+ Transfinite Line {14, 15} = nb_points Using Progression r; //+ Transfinite Line {13, 16} = 1; //+ Transfinite Line {16, 12} = 1; Extrude {0, 0, 1} { // Surface{1, 2, 3, 4}; Recombine; Surface{1, 2, 3, 4}; Layers{1}; Recombine; } Recombine Surface "*"; Transfinite Surface "*"; I also tried to use the Boundarylayer function but I do not manage to set the thickness of the boundary layer equal to the half of my channel and/or to specify the size of the cells that are beyond the boundary layer. Below is a code example for a simple rectangle: Code:
SetFactory("OpenCASCADE"); Rectangle(1) = {0, 0, 0, 1, 1, 0}; Transfinite Surface "*"; Recombine Surface "*"; Field[1] = BoundaryLayer; Field[1].EdgesList = {1}; Field[1].NodesList = {1, 2}; Field[1].hwall_n = 0.01; Field[1].thickness = 1; Field[1].ratio = 1.1; Field[1].Quads = 1; BoundaryLayer Field = 1; Code:
Field[1].thickness = 1; How can I set the size of the cells that are above the boundary layer ? Thanks a lot, Boone |
November 4, 2022, 10:19 |
bigfoot
Rep Power: 17 |
use this for the overall mesh size:
Mesh.CharacteristicLengthMin = 0.02; Mesh.CharacteristicLengthMax = 0.02; I think there is a limit to the size of the boundary layer thickness with respect to the total size of the domain, I could not make the boundary layer thickness larger than 0.4. For larger values, the thickness of the boundary layer was the same. |
November 4, 2022, 11:39 |
Rep Power: 4 |
Thanks for your answer. In the meantime I found a way to solve this issue with the background function. It works well for a single boundary layer but when multiple boundaries are used it does not work. I read that we should use the Field[] = Min; to solve this but I do not manage to make it work.
I give my script below. If someone knows how to make it works with several backgronud functions it would be great =). Code:
SetFactory("OpenCASCADE"); Dext=0.023; dy0=0.00219133; r=1.05; Ly_wall=0.7-1/3; Ly_center=0.3; Rectangle(1) = {0, 1/3, 0, 1, Ly_wall, 0}; Rectangle(2) = {0, 0.7, 0, 1, Ly_center, 0}; Rectangle(3) = {0, 1, 0, 1, Ly_center, 0}; Rectangle(4) = {0, 1+Ly_center, 0, 1, Ly_wall, 0}; Coherence; Transfinite Surface "*"; Recombine Surface "*"; Transfinite Line {5, 6} = Ly_center/Dext; Transfinite Line {8, 9} = Ly_center/Dext; Field[4] = BoundaryLayer; Field[4].EdgesList = {13}; Field[4].NodesList = {9, 10}; Field[4].hwall_n = dy0; Field[4].hfar = Dext; Field[4].thickness = Ly_wall; Field[4].ratio = r; Field[4].Quads = 1; BoundaryLayer Field = 4; // Background Field = 4; Field[1] = BoundaryLayer; Field[1].EdgesList = {1}; Field[1].NodesList = {1, 2}; Field[1].hwall_n = dy0; Field[1].hfar = Dext; Field[1].thickness = Ly_wall; Field[1].ratio = r; Field[1].Quads = 1; BoundaryLayer Field = 1; //Background Field = 1; //+ Field[5] = Min; //+ Field[5].FieldsList = {1}; //+ Background Field = 5; |
boundary layer grid, channel flow, gmsh, mesh, structure mesh |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 10:56 |
GMSH extrude a boundary layer from an unstructured Mesh | Hillie | Mesh Generation & Pre-Processing | 2 | July 7, 2017 03:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
