Defining Supersonic Outlet in Ansys Fluent
Old   October 29, 2022, 17:27
Default Defining Supersonic Outlet in Ansys Fluent
İbrahim
erkampasha is on a distinguished road
I have an hypersonic flow internal case. In user guide, it said that "Should the flow become locally supersonic, the specified pressure will no longer be used; pressure will be extrapolated from the flow in the interior. All other flow quantities are extrapolated from the interior." However when i change the backflow pressure, mach number of exit plane is changed. Secondly, in hypersonic case example in official tutorial case fluent document, pressure outlet is set 25 Pa. If it were surpass, the value would have been zero.
Could you help me about clarifying the issue?
erkampasha is offline   Reply With Quote
Old   October 29, 2022, 18:08
Lucky
There are no hard constraints at supersonic outlets that needs defining. However, you need to make sure that it is supersonic first. There are boundary conditions that will result in a subsonic flow, namely too high a pressure.
Set a low enough pressure such that the exit becomes supersonic. If you set a high enough backflow pressure, the outlet becomes an inlet!
Old   October 29, 2022, 18:40
İbrahim
already i set the values for inlet bc according to given total variables values in experiment paper. I set operating pressure 0 and inlet pressure is 557 Pa inlet temp 436 K. However i do not know what should i do for outlet. In openfoam and cfd++, i was setting supersonic outlet or zero gradient.
Old   October 29, 2022, 21:38
Lucky
To be even more clear, use a pressure outlet and set a low enough pressure such that the flow becomes supersonic.
Old   October 30, 2022, 04:59
İbrahim
i use pressure outlet and use the default value 0 Pa. Is it enough low pressure?
Supersonic 2D Ramp Air Intake Outlet Back Pressure BarisBicakci SU2 7 March 15, 2024 19:45
How to define a hole as boundary condition in Ansys Fluent using Fluent an mesh only? Nagu Sattenapalli CFD-Wiki 0 August 12, 2019 05:03
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Defining two reactions in ANSYS FLUENT arashmostaedy FLUENT 0 May 24, 2010 07:32
