Mesh refinement for downward facing step with gmsh |
October 21, 2022, 03:37 |
Rep Power: 4 |
Hello everyone,
I am a new user of gmsh3. I would like to mesh a downward facing step with structured cells. The black and white mesh (mesh.png) is similar to the one a manage to do. However, the downstream of the step edge should be meshed with fine cells and the fine area mesh is expanded in the downstream following a triangle shape as seen on the attached picture with colors (grid-plot.jpg). I managed to perform progressing mesh in the x (streamwise direction) and y (wall normal direction) directions with constant mesh progression. However, I do not succeed in having a mesh progression in the y direction that depend on the x direction (which permit obtaining the triangular shape of fine mesh region). How can I do that with gmsh3 ? Thanks a lot, Boone |
gmsh, mesh 2d, refinement, structured grid, transfinite surface |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
