Export .cdat file and report file TUI command |
October 17, 2022, 17:53 |
Rep Power: 5 |
Im running a simulation on supercomputer/cluster. I created a .cdat file and report file using the GUI. Which command can I use to export the .cdat file and the report file (.out)? Here is what I have for now: file/read-case Midout_01413m_gel_OSC_test.cas.h5 solve/iterate 1 solve/set/time-step 0.5 solve/dual-time-iterate 60 25 solve/report-files/add h-report frequency 1 report-defs h-integral-per-surface () file-name "h-report.out" q solve/report-file/add temperature frequency 1 report-defs temp-integral-per-surface () file-name "temperature.out" q file/write-data result.dat file/confirm-overwrite yes exit yes Thank you |
Fluent Journal File (TUI) Definition Invalid?? TUI Command for ''OK'' | saha.vedabit | FLUENT | 3 | July 5, 2022 00:15 |
how to write the journal file to output the moment of blades in monitors on cluster? | Cheng Biyi | FLUENT | 0 | August 18, 2021 04:04 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
