Help with HOPR meshing
Old   October 15, 2022, 21:57
Default Help with HOPR meshing
Jeff Greason
jgreason is on a distinguished road
Group, I'm trying to use the plasma simulation PIC-DSMC tool PICLas. That requires an input mesh with the program HOPR
hopr-project.org/
I'm having no luck formatting a shape (even a simple shape), that can run through HOPR. It would help immensely if I had some examples of what the input was looking for. For example, I tried generating a mesh in SALOME and exporting to CGNS (a simple sphere in 2D axial symmetry, picture of the mesh below)
But when I convert that using the same hopr.ini file supplied with PICLAS for a similar case (a 70 degree cone), I get:
Program abort caused in File : src/readin/readin_CGNS.f90 Line 132
This file was compiled at Oct 4 2022 16:38:00
Message: Base number 1 invalid
See Sphere1_2D_mesh_ERRORS.out for more details
STOP 1
If anyone has an example of a working simple 2D CGNS file I could use as a model, or otherwise can suggest a procedure, I would appreciate it.
I've attached the .ini and .cgns files renamed as .txt extension
jgreason is offline   Reply With Quote
Old   October 15, 2022, 21:58
Default additional detail on the HOPR issue
Jeff Greason
Note that Sphere1_2D_mesh_ERRORS.out is an empty file, which is why I didn't also include it
hopr
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 12:38
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 15:27
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
