About the equation for enthalpy in the UDF for Cp (specific heat) / How can I form a |
September 13, 2022, 05:41 |
ANTALYA
Rep Power: 9 |
Hi, I have been trying to import the thermophysical properties of CO2 (for the supercritical region) to Fluent by using UDF. End of the analysis, the result is not correct. I think Fluent is pulling a Tref value which causes my enthalpy to go negative; therefore, the energy equation does not give accurate temperature results, so the result of thermophysical properties, which are functions of temperature, are wrong. I want to be grateful if you could share your recommendations, especially on the methods of correct calculation of enthalpy. My specific heat code is as follows:
#include "udf.h" DEFINE_SPECIFIC_HEAT(supercritical_cp, T, Tref, h, yi) { real cp; if (300. >= T) { cp = 2.256999118844760E-02 * pow(T, 4.) - 2.606618818487370E+01 * pow(T, 3.) + 1.129129898467780E+04 * pow(T, 2.) - 2.174235523392760E+06 * T + 1.570278261279480E+08; } if (300. > T >= 306.) { cp = 1.147018354719330E+01 * pow(T, 4.) - 1.385519872072390E+04 * pow(T, 3.) + 6.276090044658930E+06 * pow(T, 2.) - 1.263530241490370E+09 * T + 9.539285116131690E+10; } if (306. > T >= 307.8) { cp = -1.611612838918710E+04 * pow(T, 4.) + 1.978085636985280E+07 * pow(T, 3.) - 9.104578256081260E+09 * pow(T, 2.) + 1.862478067464320E+12 * T - 1.428738938943020E+14; } if (307.8 > T >= 310.) { cp = -1.576135476848110E+03 * pow(T, 4.) + 1.945866130859760E+06 * pow(T, 3.) - 9.008641337104630E+08 * pow(T, 2.) + 1.853611584329810E+11 * T - 1.430227164258690E+13; } if (310. > T >= 320.) { cp = 1.770529718817220E+00 * pow(T, 4.) - 2.242833202341920E+03 * pow(T, 3.) + 1.065432793165650E+06 * pow(T, 2.) - 2.249454519629040E+08 * T + 1.781003821884030E+10; } if (320. > T) { cp = 2.086961941877520E-03 * pow(T, 4.) - 2.851496372954040E+00 * pow(T, 3.) + 1.461548345109060E+03 * pow(T, 2.) - 3.330816449664890E+05 * T + 2.848088978782360E+07; } *h = cp*(T-Tref); return cp; } Last edited by erginbayrak; September 13, 2022 at 09:18. |
use of pointers in specific heat udf | mdakbari | Fluent UDF and Scheme Programming | 0 | April 18, 2014 12:37 |
having problem in writing a UDF for specific heat in fluent 14.0 | nands_bullwalker | Fluent UDF and Scheme Programming | 1 | June 29, 2013 11:32 |
How to write udf for specific heat | nanoraja | ANSYS Meshing & Geometry | 1 | September 14, 2011 12:34 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 03:21 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
