y+ for EFM or FVM
Old   September 12, 2022, 22:53
Default y+ for EFM or FVM
Suk Tan
suktan is on a distinguished road
Dose y+ depend on the choice of using FVM or FEM approach?
suktan is offline   Reply With Quote
Old   September 13, 2022, 05:27
bigfoot
bigfootedrockmidget is on a distinguished road
y+ is just a nondimensional distance to the wall. It depends on the wall shear stress, so the actual value of y+ depends on the numerical solution. The value of y+ at the first node away from the wall is important because it tells you if your mesh resolves the boundary layer sufficiently.
Here's a nice youtube video for you:
difference between y+ and y*:
https://www.youtube.com/watch?v=nSdVaF3JnI0
and also y+ for wall functions:
https://www.youtube.com/watch?v=fJDYtEGMgzs&t=1132s
bigfootedrockmidget is offline   Reply With Quote
Old   September 13, 2022, 09:32
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
So, formally no, it doesn't depend on the method. Y+ is just a non dimensional quantity involving a length, velocity, density and viscosity. It is a Re number based on viscous scales.
However, in practice, at least for the velocity and length scales you use for it, you have a dependence on the method for the same mesh. Because the location where y+ can be practically computed in FEM is different from the one where it can be computed for FVM, which in turn, for certain cases, can also impact the wall stress computation. Finally, even the wall stress might be computed in a formally different way in FEM and FVM.
In conclusion, y+ obviously is a single concept, but you won't probably get the same y+ for the same mesh with FEM and FVM (besides the other obvious differences between the two methods which, where relevant, would make the numerical solution further different)
sbaffini is online now   Reply With Quote
Trying to understand FDM vs FVM vs Conservative form vs Non-conservative form granzer Main CFD Forum 5 December 4, 2019 04:00
Practical difference between FVM and LBM? pharg_yrartibra Main CFD Forum 2 November 25, 2013 11:52
FVM in 1-D spherical coordinates lost.identity Main CFD Forum 0 January 17, 2011 10:06
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
References for FVM Anthony Wachs Main CFD Forum 8 February 20, 2002 20:23
