September 6, 2022, 20:50 |
Calculating Sutherland law's input
İbrahim
Rep Power: 9 |
I need sutherland function for ethylene. For two coefficient method C1 and C2 are required, for three coefficient method S, ref Temp and ref viscosity.
How can i obtain these input? |
September 7, 2022, 01:14 |
Lucky
Rep Power: 66 |
1) In general you use a database of viscosity and curve fit it using regression software. Note that transport properties are a function of temperature and pressure, so you should do this fit at the desired operating pressure but most people don't have such a database and often use atmospheric properties and blindly apply them to pressures like 100 bar.
2) You steal it from someone else's work and inconveniently forget to cite the source. |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
Calculating pitching moment for power input | Zonexo | Main CFD Forum | 0 | June 12, 2008 06:07 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
