Simulate Vacuum Region Between Two Solid Bodies in ANSYS Fluent |
September 6, 2022, 09:10 |
Mohammed
Hi All,
I hope you are enjoying your time. I am preparing a 2D simulation in ANSYS Fluent to simulate the heat transfer inside an empty box. Around this empty box, there are two solid boxes and one box with vacuumed pressure to provide insulation for the empty box and prevent heat transfer with the surrounding; please see the attached picture for more explanation. https://ibb.co/qgywJ6w My question is, am I able to simulate this case in ANSYS Fluent? If yes, how can I prepare the vacuum region between solid bodies in ANSYS? I hope the explanation is clear and you got the idea. Thank you in Advance. Last edited by Mohalatif; September 6, 2022 at 09:13. Reason: Attaching a picture |
September 6, 2022, 11:45 |
Lucky
Rep Power: 66 |
Mesh everything. Give the real properties to the fluid in the vacuum region (air?) and set the pressure equal to the vacuum pressure. You can use a pressure inlet or outlet, I recommend a pressure inlet.
Negative initial temperature error (chtMultiRegionFoam) | jebin | OpenFOAM Pre-Processing | 60 | July 17, 2022 05:10 |
ANSYS Fluent errors "Attach Failed" and "No Valid bodies Found" | Bertman | FLUENT | 3 | December 24, 2021 17:15 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
Modeling vacuum suction through pipe in ANSYS Fluent | mamoody14 | FLUENT | 1 | February 20, 2019 14:09 |
import to Ansys Fluent Design modeler shows 4141 parts and bodies | samnath | FLUENT | 5 | April 6, 2015 02:22 |
