Doublet influence matrix vortex panel method
Old   September 1, 2022, 11:45
Default Doublet influence matrix vortex panel method
L.
lWiNdY is on a distinguished road
In "Katz & Plotkin: Low speed aerodynamics" the idea of the equivalence between a constant doublet panel and a vortex ring panel is discussed and proved. This allows the evaluation of the effect of doublet \mu by means of a closed vortex ring which is an easier expression if you ask me.
However, and I have seen it in multiple papers/books, on 356 of K&P it is stressed that a_{jj}=0.5, where a_{ij} is the entry of the doublet influence matrix. That is, the effect of a unit strength doublet of panel j on the normal velocity at collocation point of panel j is a half.
This does not make sense in my opinion. Suppose we have a square panel with it's collocation point at [0,0,0]. Then, if we double the size of each vertex, the distance from each vertex (or vortex line) is increased and its influence is reduced.
I have attached a very simple python (in .txt) code which basically mimics the VORRING subroutine (eq 10.117, K&P) and if you play with the numbers it is simply confirmed that the influence on its own collocation point is not 0.5. For sources however this seems to be the case.
To that extend, are there any basic sanity checks to see whether or not the source/doublet influence matrices are constructed correctly? And do you agree with my point?
Last edited by lWiNdY; September 1, 2022 at 11:46. Reason: weird attachment appeared
lWiNdY is offline   Reply With Quote
Old   September 5, 2022, 11:16
L.
I was mistaken; The velocity POTENTIAL influence matrix has this property. Not the velocity influence matrix!! Therefore, the question is irrelevant and the thread can be considered closed.
influence matrix, panel method
Advice on coupled panel method jancellor Main CFD Forum 0 October 6, 2018 13:20
singularity distribution about panel method rogerliu Main CFD Forum 2 February 5, 2013 13:30
does vortex panel method satisfy no-penetration boundary condition? rogerliu Main CFD Forum 1 December 3, 2012 05:40
Problem building 3D Panel Method Daniel Main CFD Forum 0 September 15, 2006 08:51
calculating missle configuration by panel method Daniel Main CFD Forum 5 January 6, 2003 09:09
