September 1, 2022, 09:57 |
what is problem my OpenFoam setting?
DongCheon
Rep Power: 4 |
Hi, I conducted OpenFOAM simulation, 2D airfoil naca0012 case.
But, I can't resolve problem. I conducted my OpenFOAM case at Mach = 0.15, and AOA = 0; My plotted pressure coefficient is too low or too high 0.8 ~ -0.6 I used my own O - grid. and y+ < 1. Here's my setting files. 1. U /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (51.4815 0 0); boundaryField { Airfoil { type noSlip; } FarField { type freestream; freestreamValue uniform (51.4815 0 0); value uniform (51.4815 0 0); } Sides { type empty; } } // ************************************************** *********************** // 2. nuTilda /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 3.432e-05; boundaryField { Airfoil { type fixedValue; value uniform 0; } FarField { type freestream; freestreamValue uniform 3.432e-05; value uniform 3.432e-05; } Sides { type empty; } } 3. nut // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 8.68e-06; boundaryField { Airfoil { type nutUSpaldingWallFunction; value uniform 0; } FarField { type freestream; freestreamValue uniform 8.68e-06; value uniform 8.68e-06; } Sides { type empty; } } // ************************************************** *********************** // 4. P /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Airfoil { type zeroGradient; } FarField { type freestreamPressure; value uniform 0; } Sides { type empty; } } // ************************************************** *********************** // 5. transportProperties /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // transportModel Newtonian; rho [1 -3 0 0 0 0 0] 1.2; nu [0 2 -1 0 0 0 0] 8.58e-06; // ************************************************** *********************** // 6. turbulenceProperties /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RAS; RAS { RASModel SpalartAllmaras; turbulence on; printCoeffs on; } // ************************************************** *********************** // 7. Controldict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 50; deltaT 0.01; writeControl timeStep; writeInterval 500; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; ///// functions { #includeFunc residuals } // ************************************************** *********************** // 8. fvSchemes /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda); div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } // ************************************************** *********************** // 9. fvSolution /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 0.01; smoother GaussSeidel; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.01; } nuTilda { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; nuTilda 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; nuTilda 0.7; } } // ************************************************** *********************** // Is there any problem??? plz help me.. |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 07:54 |
If my problem diverges in OpenFOAM ver3, will it work in 5 | quarkz | OpenFOAM Running, Solving & CFD | 3 | April 26, 2018 03:09 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox | Stubby | OpenFOAM Installation | 8 | March 5, 2012 16:12 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 12:32 |
