Where is the problem in UDF (FLUENT) for cp as a function of Temperature? |
August 31, 2022, 04:17 |
ANTALYA
Rep Power: 9 |
Hi, I take a compiled error from my code as follows;
supercritical_cp.c ..\..\src\supercritical_cp.c(3): error C2065: 'real': undeclared identifier ..\..\src\supercritical_cp.c(3): error C2146: syntax error: missing ';' before identifier 'cp' ..\..\src\supercritical_cp.c(3): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(7): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(11): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(15): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(19): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(21): error C2100: illegal indirection ..\..\src\supercritical_cp.c(21): error C2065: 'cp': undeclared identifier ..\..\src\supercritical_cp.c(22): error C2065: 'cp': undeclared identifier Done. My code is; DEFINE_SPECIFIC_HEAT(supercritical_cp, T, Tref, h, yi) { real cp; if (306. >= T >= 285.) { cp = 0.0029 * pow(T, 6.) - 5.0805 * pow(T, 5.) + 3733.1 * pow(T, 4.) - 1e+6 * pow(T, 3.) + 3e+8 * pow(T, 2.) - 4e+10 * T + 2e+12; } if (307.8 >= T > 306.) { cp = 2342.3 * pow(T, 6.) - 4e+6 * pow(T, 5.) + 3e+9 * pow(T, 4.) - 1e+12 * pow(T, 3.) + 3e+14 * pow(T, 2.) - 4e+16 * T + 2e+18; } if (310. >= T > 307.8) { cp = -4663.3 * pow(T, 6.) + 9e+6 * pow(T, 5.) - 7e+9 * pow(T, 4.) + 3e+12 * pow(T, 3.) - 6e+14 * pow(T, 2.) + 8e+16 * T - 4e+18; } if (350. >= T > 310.) { cp = 8e-5 * pow(T, 6.) - 0.1631 * pow(T, 5.) + 135.66 * pow(T, 4.) - 60154 * pow(T, 3.) + 1e+7 * pow(T, 2.) - 2e+9 * T + 1e+11; } *h = cp*(T-Tref); return cp; } I would like to be grateful if you could say your recommendations. Regards, |
August 31, 2022, 05:13 |
Rep Power: 16 |
Could it be that you forgot to include udf.h or that it can't be located ? edit: probably unrelated to your error but what happens to cp if T does not lie in [306,350] ? You should consider default values when using if statements. |
September 6, 2022, 05:49 |
#3 | |
ANTALYA
Rep Power: 9 |
My Code #include "udf.h" DEFINE_SPECIFIC_HEAT(supercritical_cp2, T, Tref, h, yi) { real cp; if (285. > T) { cp = 2540.85; } if (306. >= T >= 285.) { cp = 0.0029 * pow(T, 6.) - 5.0805 * pow(T, 5.) + 3733.1 * pow(T, 4.) - 1e+6 * pow(T, 3.) + 3e+8 * pow(T, 2.) - 4e+10 * T + 2e+12; } if (307.8 >= T > 306.) { cp = 2342.3 * pow(T, 6) - 4e+6 * pow(T, 5) + 3e+9 * pow(T, 4) - 1e+12 * pow(T, 3) + 3e+14 * pow(T, 2) - 4e+16 * T + 2e+18; } if (310. >= T > 307.8) { cp = -4663.3 * pow(T, 6) + 9e+6 * pow(T, 5) - 7e+9 * pow(T, 4) + 3e+12 * pow(T, 3) - 6e+14 * pow(T, 2) + 8e+16 * T - 4e+18; } if (350. >= T > 310.) { cp = 8e-5 * pow(T, 6) - 0.1631 * pow(T, 5) + 135.66 * pow(T, 4) - 60154. * pow(T, 3) + 1e+7 * pow(T, 2) - 2e+9 * T + 1e+11; } if (T > 350.) { cp = 1546.34; } *h = cp*(T-Tref); return cp; } Error: WARNING: Invalid cp (0.000000e+00 J/kgK) for carbon-dioxide at temperature 289.692000 K iter continuity x-velocity y-velocity energy k omega intermit retheta time/iter Stabilizing pressure coupled to enhance linear solver robustness. Stabilizing pressure coupled using GMRES to enhance linear solver robustness. Experiencing convergence difficulties - temporarily relaxing and trying aga ivergence detected in AMG solver: pressure coupled Stabilizing k to enhance linear solver robustness. Stabilizing k using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: pressure coupled Divergence detected in AMG solver: k Divergence detected in AMG solver: omega Divergence detected in AMG solver: intermit Divergence detected in AMG solver: retheta Divergence detected in AMG solver: temperature WARNING: Invalid cp (0.0000Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error at Node 3: floating point exception 00e+00 J/kgK) for carbon-dioxide at temperature 289.692000 K Error at Node 4: floating point exception Error at Node 5: floating point exception Error at Node 6: floating point exception Error at Node 7: floating point exception Error at Node 8: floating point exception Error at host: floating point exception Error at Node 9: floating point exception Error at Node 10: floating point exception Error at Node 11: floating point exception Error: floating point exception Error Object: #f |
September 6, 2022, 06:01 |
Rep Power: 16 |
I don't have experience with fluent so I can just provide very general help here. If I were you I would double check first the correlations you are using by plotting them for each temperature range. Hand computing your correlation at T=289.692K gives an unrealistic value for cp ~ 10^12 |
Getting density, temperature, and other cell flow variables via macros in Fluent UDF | ingabobjoe | Fluent UDF and Scheme Programming | 2 | August 15, 2020 21:08 |
How To write a Correct UDF (FLUENT) for Specific heat as Function of Temperature for | atulsbhat | FLUENT | 4 | December 10, 2019 10:57 |
Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 05:32 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
