Need help to validate my simulation result
Old   August 22, 2022, 10:13
Default Need help to validate my simulation result
Tintunoo
Tintun is on a distinguished road
problem description -
-free fall rocket like object drop from 500 meters.
-desired results are forces and moment coefficient for rigid body simulation.
-free stream velocity 60 m/s.
-angle of attack 5 deg.
simulation setup -
-box far field domain 10 times body length for 3D simulation.
-inlet, top and bottom patches are velocity inlet type.
-symmetry sides.
-pressure outlet.
-turbulent Model is kOmegaSST.
-simpleFoam solver.
Mesh
-snappyHexMesh with 3 boundary layers of thickness 0.7
-total number of cell 1 Million.
HTML Code:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (59.771681 5.02293445 0);
boundaryField
    airdrop
        type            noSlip;
    inlet
        type            fixedValue;
        value           uniform (59.771681 5.02293445 0);
    outlet
        type            zeroGradient;
    sides
        type            symmetry;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "1";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    airdrop
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    sides
        type            symmetry;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "1";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 864200;
boundaryField
    airdrop
        type            omegaWallFunction;
        value           uniform 1;
    inlet
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    0.014;
        value           uniform 0.014;
    outlet
        type            zeroGradient;
    sides
        type            symmetry;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "1";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    airdrop
        type            nutkWallFunction;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0.01934;
    outlet
        type            calculated;
        value           uniform 0;
    sides
        type            symmetry;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "1";
    object      k;
internalField   uniform 0.1;
boundaryField
    airdrop
        type            kqRWallFunction;
        value           uniform 1;
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.01;
        value           uniform 0.01;
    outlet
        type            zeroGradient;
    sides
        type            symmetry;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
transportModel  Newtonian;
nu              1.5e-05;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType RAS;
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         15000;
deltaT          1;
writeControl    timeStep;
writeInterval   10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
	forceCoeffs1
    type            forceCoeffs;
    libs            ("libforces.so");
    writeControl    writeTime;
    writeFields     true;
    patches         (fuckingbomb);
    p               p;
    U               U;
    rho             rhoInf;      // Indicates incompressible
    log             true;
    rhoInf          1;           // Required when rho = rhoInf
    liftDir         (0 1 0);
    dragDir         (1 0 0);
    CofR            (0 0 0);  // Axle midpoint on ground
    pitchAxis       (0 0 1);
    magUInf         60;
    lRef            2.41;          // Wheelbase length
    Aref            4.56;          // Estimated
yPlus1
    // Mandatory entries (unmodifiable)
    type            yPlus;
    libs            (fieldFunctionObjects);
    // Optional (inherited) entries
    writePrecision  8;
    writeToFile     true;
    useUserTime     true;
    region          region0;
    enabled         true;
    log             true;
    timeStart       0;
    timeEnd         1000;
    executeControl  timeStep;
    executeInterval 1;
    writeInterval   10;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,k)      bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.1;
        smoother         GaussSeidel;
    Phi
        $p;
    U
        solver           smoothSolver;
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    k
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    omega
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 3;
potentialFlow
	nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        "(U|k|omega)"   0.7;
        "(U|k|omega)Final" 1.0;
cache
    grad(U);
Result -
only Ux and omega resudual went below 1e-5.
other residual doesn't goes below 1e-3.
-yplus value are y+ : min = 81.6281, max = 13216.4, average = 1185.81
HTML Code:
Time = 639
smoothSolver:  Solving for Ux, Initial residual = 9.52204e-05, Final residual = 6.89428e-06, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.000402492, Final residual = 2.90737e-05, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 0.00496712, Final residual = 0.000361654, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.00923487, Final residual = 0.000304668, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.0010415, Final residual = 5.96551e-05, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.000171178, Final residual = 1.68851e-05, No Iterations 2
GAMG:  Solving for p, Initial residual = 4.20648e-05, Final residual = 2.52407e-06, No Iterations 3
time step continuity errors : sum local = 6.28704e-08, global = 1.01751e-09, cumulative = 0.00119196
smoothSolver:  Solving for omega, Initial residual = 2.4579e-05, Final residual = 1.75449e-06, No Iterations 3
smoothSolver:  Solving for k, Initial residual = 0.000100212, Final residual = 7.69947e-06, No Iterations 3
ExecutionTime = 3194.77 s  ClockTime = 3379 s
forceCoeffs forceCoeffs1 execute:
    Coefficients
        Cd       : 0.267388	(pressure: 0.251521	viscous: 0.0158662)
        Cs       : -0.0281329	(pressure: -0.0283496	viscous: 0.000216715)
        Cl       : 0.337512	(pressure: 0.336583	viscous: 0.000929208)
        CmRoll       : 0.206183	(pressure: 0.205689	viscous: 0.000494358)
        CmPitch       : 0.669585	(pressure: 0.657872	viscous: 0.011713)
        CmYaw       : -0.125541	(pressure: -0.116004	viscous: -0.00953733)
        Cd(f)    : 0.339877
        Cd(r)    : -0.0724894
        Cs(f)    : -0.139607
        Cs(r)    : 0.111475
        Cl(f)    : 0.838341
        Cl(r)    : -0.500829
Question -
-is my result acceptable and how can i improve to have convergance. Thank in advances.
Tintun is offline   Reply With Quote
convergence issue, free fall analysis, incompressible fluid, simple algorithm
Unusual oscillation in my MHD simulation result nothingts Main CFD Forum 0 June 6, 2019 08:05
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
How to separate two waves in my simulation result? hadesmajesty Main CFD Forum 0 October 13, 2009 01:42
Single phase result file for multiphase simulation Kushagra CFX 2 July 8, 2008 22:14
transient simulation result file (.trn) ? amine CFX 3 June 14, 2008 06:01
