Dense asymmetric rank-deficient linear system |
August 20, 2022, 23:28 |
Mingming Zhang
Rep Power: 6 |
Hi guys,
I just run into a dense asymmetric rank-deficient system (see attached fig). This system comes from a Fourier-Chebyshev approximation of thermal convection in an annulus. Its condition number is as high as 1.0e14 and would increase if we use higher spatial resolution. The author uses dgetrf to do LU factorization and then dgetrs to solve a similar system, but they're not the same. Any suggestions? Thanks. PS: for example, a 514*514 matrix, its rank is 507, condition number is 9.0e14. Best, Mingming |
September 1, 2022, 22:52 |
#2 | |
Mingming Zhang
Rep Power: 6 |
This dense matrix can be solved by LAPACK routines DGETRF and DGETRS, also MATLAB \ operator will work. So this post will end here. Thanks Mingming |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 08:56 |
On the block tridiagonal linear system | zhanglei | Main CFD Forum | 2 | July 24, 2000 06:15 |
On the block tridiagonal linear system | zhanglei | Main CFD Forum | 0 | July 18, 2000 08:55 |
solver for linear system with large sparse matrix | Yangang Bao | Main CFD Forum | 1 | October 25, 1999 04:22 |
