Rotor-Stator cavities - cfd
Old   August 11, 2022, 11:17
Arrow Rotor-Stator cavities - cfd
ocb
Nazım
ocb is on a distinguished road
Two compressor rotor-stator cavities are given in attachment. The flow direction of the air in the compressor is also indicated by the arrow.
Can you explain the flow and physical effects in these cavities? For example:
Where does the flow enter and exit the cavities?
What is the characteristic of the flow in the cavity? Ex. Is there a circulation or does the flow proceed uniformly inside the cavity? If circulation is happening, in what direction?
What is the element circled in red and its function?
If you wanted to model the flow here in CFD, what setup would you set up, e.g. What would be the entrance-exit boundary conditions, the boundary conditions to be used on the wall, the turbulence model? Is it necessary to model heat transfer on the wall?
ocb is offline   Reply With Quote
cavity, compressor, rotor-stator
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 16:18
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 13:23
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 05:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
