Turbulance Model for Prediction of Stall Characteristics |
August 11, 2022, 04:46 |
Hello.,
I'm trying to simulate the model between the range of RE = 3.5E-05 to 4.5E-05. I tried k-omega SST model with y+ of 30 for the velocity range of 25-35 m/s and Ange attack of -10 to 20 with the step of 5. But some reference discussions preferred k-epsilon with Grid independent studies. As per my knowledge, K-omega also uses the base scheme as k-epsilon in addition to wall functions. Is it preferable to use k-omega(which basically captures adverse pressure gradient)at higher angle of attack to validate CL, CD and CM ? Thank you.. Last edited by KDG; August 12, 2022 at 01:55. |
cfd aerospace, low re, stall angle, turbule model |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
viewFactor radiation model stuck | shach934 | OpenFOAM | 1 | May 25, 2021 11:01 |
turbulance model | melek | FLOW-3D | 0 | January 8, 2014 12:27 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
How to change the turbulance model | sivakumar | OpenFOAM Pre-Processing | 9 | February 17, 2009 05:56 |
