Wierd looking velocity contour for DrivAer external airflow simulation
Old   August 3, 2022, 06:18
Default Wierd looking velocity contour for DrivAer external airflow simulation
Barry
barry_1 is on a distinguished road
Hi. I recently tried to do some velocity plots using a DrivAer car model on ANSYS Fluent. I have ended up with some really wierd "lightning-like" lines on my plots. I don't know why this is happening and want to know if I'm doing something wrong here. Could anyone point out what's going on?
Few details :
* K-omega SST turbulence model was used
* Inlet velocity was 40m/s and moving ground
* DrivAer model without wheels and smooth underbody was used
* Domain - 3L in front, 5L in the rear, 3H above and 3W for the side.
I have attached pictures for your reference.
Thank you in advance
barry_1 is offline   Reply With Quote
Old   August 3, 2022, 12:22
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I remember having similar issues (a decade ago), which are related to the parallel decomposition, but I honestly don't remember anymore when and why this happened, if it was my fault or Fluent fault, and if there was a fix about it.
If I had to point to something, it might be due to the node (as opposed to cell) visualization and the gradients probably not available yet, which probably happens when you first launch Fluent in parallel and go straight to the visualization without computing.
Try making a single iteration at least or switching to the cell visualization of the variables
sbaffini is offline   Reply With Quote
drivaer, external aerdynamics, fluent 14.0, velocity contours
write bc data and read it for other simulation jdp810 SU2 1 May 8, 2021 18:04
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour Caster_Troy FLUENT 1 December 7, 2017 07:19
In CFD-post, why wall velocity value is not consistant with that of the contour? Andy Von CFX 2 December 13, 2015 23:40
Simulation Pausing Durning Velocity Profile Update CaptainCombo ANSYS 1 September 4, 2015 11:55
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
