water splash simulation for real wheel of bike |
Bagmati
Rep Power: 0 ![]() |
I am working on a project based on the simulation of water splash generated by the rear wheel of a bike.
I want to simulate the trajectory of water caused by the wheel. I started with following setup and boundary condition A wheel geometry enclosed by two enclosure both cubical box based on hex dominant and tet dominant mesh. I used tet dominant mesh for enclosure near to the geometry as the flow around the wheel is of major concern. Boundary included: Ground : moving along x-axis inlet : velocity along x-axis for air wheel walls: set to rotation about the origin along z axis outlet: at gauge pressure Model used : VOF phase 1 : air phase 2: water, Implicit method Result obtained: https://youtu.be/sa7e6Uh7i_Y I used pseudo transient method to get the above result. I don't know my simulation result are able to capture any physics of such problem. Is there any better approach to solve this type of problem? I read about mrf approach but as my problem involves both translational and rotational effects I am not sure mrf approach would be good for this problem. |
Arjun
Rep Power: 34 ![]() ![]() |
Bagmati
yeah .. but there is no details of setup of anything in the link you provided. can someone provide me any better reference?
mrf. moving wall, turbomachinery cfd, vof model |
water injection error (modify the position of water injection) | wjchoi | Main CFD Forum | 0 | January 17, 2022 07:17 |
Errors in simulation of water entry of cylinder or wrong physics when done. | GhostOfAres | FLUENT | 0 | April 22, 2021 10:17 |
Wrong oscillatory torque of a water wheel | Ema40 | FLUENT | 2 | September 5, 2016 10:29 |
static pressure in water wheel and open ambient | Ema40 | FLUENT | 0 | November 13, 2014 02:57 |
Simulating Water Splash Using a Particle System | Zi-Wei Chiou | Main CFD Forum | 0 | March 4, 2002 06:33 |
