July 25, 2022, 08:24 |
Isolate PVC with the Q-citerion
velkon123
Rep Power: 6 |
Hi!
I am trying to isolate a precessing vortex core with the Q criterion. However because there are a lot of other structures visible when imposing a certain Q value, I can not see the PVC properly. Does anybody know a method where you can isolate the 3D PVC with the Q-criterion. Kind regards, Last edited by velkon; July 25, 2022 at 09:57. |
July 27, 2022, 04:18 |
The stupid question first: does your velocity field suggest that a PVC is actually present?
Second, have you tried with different Q values? I only worked on a single geometry with multiple swirl ratios, but I was able to visualize it both with the Q and lambda criterions. |
July 27, 2022, 04:21 |
#3 | |
velkon123
Rep Power: 6 |
Thank you for your response. Yes from POD and experimental results it is clear that a PVC is present in the flow. Furthermore I can see the PVC with the Q criterion when imposing different values. However a lot of other structures are still also present making it hard to see it. Do you perhaps know how to isolate the PVC from those other structures? |
July 27, 2022, 04:55 |
#4 | |
What solver/visualizer are you using? How is your Q defined? Is it possible that it is coded wrong? |
pvc, q-criterion, stability, swirl |
How to isolate a particular section when a plane crosses multiple sections ? | NicolasMisiara | CFX | 2 | July 24, 2020 03:52 |
Isolate Washer | shubham04 | ANSA | 1 | July 10, 2020 00:50 |
[General] How to isolate geometric elements in a solution file? | Jasfss | ParaView | 0 | January 17, 2017 10:14 |
roughness values for PVC piping | Nick Thomsen | Main CFD Forum | 2 | February 9, 2000 12:04 |
