Software works weird; Processor 3995WX
Old   July 21, 2022, 10:02
Question Software works weird; Processor 3995WX
Ilya
offroader10052 is on a distinguished road
Hello.
I ask for advice.
I bought an AMD Ryzen Threadripper PRO 3995WX processor and can't use it to its full potential.
Problem:
The same task in Ansys CFX is solved at different speeds.
Each new run of the solution gives a solution at a different speed.
test 1 - 3200 seconds
test 2 - 900 seconds
test 3 - 7000 seconds
test 4 - 1400 seconds
How to achieve the same minimum solution time?
PC specifications
- AMD Ryzen Threadripper PRO 3995WX (64 physical cores, 128 threads);
- 128 GB RAM;
- 512 SSD samsung evo;
- no throttling occurs, temperature 50-55 °C;
- Windows 10 x64;
- Ansys 19.1.
Did not help:
- disable hyper trading
- disable turbo boost
- reinstall win to another copy
- ssd replacement
- Installing another version of Ansys 2021
- installation of all driver and OS updates.
Other programs run fine on this PC with the same repeatable results (benchmarks, video encoding, rendering).
offroader10052 is offline   Reply With Quote
Old   July 21, 2022, 18:45
naffrancois is on a distinguished road
Can you provide more info on the test case you are running ? How many cells ? Which model ? How many threads are you using ?
naffrancois is offline   Reply With Quote
Old   July 22, 2022, 03:32
Ilya
2.500.000 cells
I count in CFX
Hydrocyclone of standard design.
Includes oil and water.
I have run successfully this model before on another computer
I tried testing on 4, 10, 12, 16 cores (threads)
Old   July 22, 2022, 04:11
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Which memory are you using exactly? How is it populated on the motherboard? Which motherboard? Which version of Windows 10?
flotus1 is offline   Reply With Quote
Old   July 22, 2022, 04:29
Ilya
DDR4 ECC REG
The motherboard has 8 memory slots.
The processor has 8 memory channels.
I'm using 4 32gb memory slots.
Windows 10 Pro x64
Old   July 22, 2022, 05:01
flotus1's Avatar
Alex
There should be a memory population guideline in your motherboard manual. Following this is important when using less than 8 DIMMs.
Regardless, you need 8 identical DIMMs to use the full capabilities of this processor. High runtime variance is a direct result of not populating all memory channels. Whether this is the only issue here, I can't tell. But it is definitely a contributing factor.
ansys, cfx, solution
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito Main CFD Forum 1 February 19, 2019 03:11
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito CFX 1 January 29, 2012 18:48
[Other] What software should i learn? - Meshing Anima ANSYS Meshing & Geometry 2 November 14, 2011 12:53
New software for simulating laminar flows HectorRedal Main CFD Forum 1 April 27, 2011 14:59
Waterhammer software Andris Skattebo Main CFD Forum 1 July 18, 1998 22:01
