How to model heat transfer in a concentric pipe?
Old   July 18, 2022, 14:09
Default How to model heat transfer in a concentric pipe?
Saketh Bharadwaj
Saketh Bharadwaj is on a distinguished road
I am trying to model a 3D heat transfer problem in COMSOL v6. The geometry is very simple and attached below. The length of model is 2m. Rectangular block is 200mm * 160mm.
The point of interest is to calculate equivalent thermal conductivity of air. Thermal conductivity of air in this region depends on all 3 types of heat transfer. Radiation is from the enclosing material (Insulation material on inner side and steel on the outer side)
Conduction and Radiation can be modelled easily. But including the convective effects is little tricky. Ideally, whole of the system should be simulated with induced velocity. But including a lot of physics is making the computation tediously long.
Does anyone how to model this case? One way is to consider analytical Nusselt number correlations. But I do not know how to couple this correlation as my model is also dependant on radiation.
Thanks.
Saketh Bharadwaj
Saketh Bharadwaj is offline   Reply With Quote
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 03:55
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
No Display of Heat Transfer Graphs For Double Pipe Heat Exhanger in CFX Solver Shomaz ul Haq CFX 17 November 25, 2015 23:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
