How to export a csv file for a specific curve in a geometry? |
July 15, 2022, 07:11 |
Rep Power: 4 |
I wanted to generate a polyline in Post-CFD but with the help of 'From File' because other methods didn't work.
July 15, 2022, 13:07 |
Rep Power: 4 |
I created this question and I am answering it because I found a way and I think this will be helpful to someone.
So just open your geometry in ICEM CFD, check the Surfaces. -> Go to Create/Modify Curve under Geometry tab.-> Select the required surface-> Click on Surface Parameter present at the left bottom. Adjust the parameter to get your required curve->Apply. Then,in the left tree, right click on Parts-> Create Part->Choose the curve you created->Apply->OK. Delete other parts (curves/surfaces you don't want) and save the geometry as a .tin file. Then go to the folder where your .tin file is saved, and open the file with Notepad. In the opened file, you can go scroll down to get the points of your curve, with an extra index. Copy those datapoints and create a new file in excel and using Text import wizard, delimit at a comma and paste. Remove the last index column. Now you can save the file as a .csv file and import it in CFD post to get the required polyline. |
cfd - post, csv, curves, from file, icem |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
