Sung jin Bae
Rep Power: 5 ![]() |
I'm currently simulating flow inside a reverse-osmosis membrane channel (feed side) with spacers included. The problem is, I want to quantify recirculation zones occurring behind the spacers as the zones with low-velocity are accumulated with solute and are prone to fouling. These spacer configurations are to be compared so that I can see which configuration is the best.
I have read other posts regarding post-processing recirculation regions, but in my case, I don't believe any of those apply to my case because i) my simulation is carried out in 3D; making a cross sectional area and computing the flow that passes it won't capture the flow rate accurately. ii) my simulation conditions have low Reynold's number. I don't see much recirculation with velocity vector profiles. Why aren't the recirculation zones visible? I have tried viewing shear stress and shear stress parallel to the flow direction. I'm not sure if integrating it gives me an accurate result. Any suggestions? |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
For a 3D flow, I suggest to detect the vortical structures using a methods such as the lambda-2.
Sung jin Bae
I've just read the Lambda2 method on detecting recirculation regions. As far as I know, there aren't any built-in methods for doing this in CFX post. Do I have to define a variable via expressions and variable to detect the vortices?
#4 | |
However, Tecplot has also the internal lambda-2 representation but I don’t like how it works. |
Recirculation Outlet DPM Boundary Conditions | afiefaldy | FLUENT | 2 | December 21, 2023 04:08 |
Plot X vs. Y for all zones for non-linear zones | aerojpapp | Tecplot | 3 | July 25, 2022 19:06 |
Quantitatively evaluate the recirculation zones | mejahan | CFX | 6 | October 13, 2020 05:00 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 14:22 |
Building problems with cell zones when reopening Fluent | MJ2017 | FLUENT | 0 | October 14, 2017 08:11 |
