Wall friction and heat transfer in flexi with FLEXI_FV=ON
Old   July 13, 2022, 07:41
Default Wall friction and heat transfer in flexi with FLEXI_FV=ON
Vachan Potluri
vachan is on a distinguished road
Dear all,
I am using flexi (https://www.flexi-project.org/) for a supersonic turbulent flow simulation. In my case, it turned out that most cells lying on the walls required limiting and hence were converted to FV subcells.
When I plot the wall friction results and compare with other simulations, I find my results slightly off at some locations (pic attached). Also the variation shows a staircase-like behaviour, with non-smooth transition between elements. Pressure variation matches well (pic attached).
I am suspecting this is because of the wall cells being converted to FV subcells. Is this really the case? Or does flexi give the correct wall friction/heat transfer results even with wall cells being converted to FV subcells? Is there a preferred and correct way to compute these wall quantities (that depend on solution gradients) in case wall cells require limiting?
Thanking in anticipation
Vachan
vachan is offline   Reply With Quote
Old   July 15, 2022, 05:14
mblin is on a distinguished road
Hi Vachan,
since FLEXI is a DG code you will almost always see small oscillations in the boundary layer indicating that you are a bit under resolved.
However, having FV cells directly next to a wall is not that preferable since the quality of the solution is not as good as for DG elements. Thus, I would suggest that you try to tune your indicator to remove the need for FV elements in the boundary layer.
You can compute the wall quantities by either using the posti_visu tool or by using the BL_Plane in the record point tool (see NACA tutorial).
Hope this helps.
Best
Marcel
mblin is offline   Reply With Quote
Old   July 15, 2022, 06:58
Vachan Potluri
Dear Marcel,
Many thanks for responding!
I agree! I am currently trying to run a finer grid simulation using the coarse converged solution as the initial condition. This I am planning to achieve through posti_swapmesh tool. I am facing some problems here too, which are documented in this thread Usage of flexi's posti_swapmesh tool.
Again, you are correct. I currently use Persson's indicator with density variable. When I tried to use pressure the simulation was facing starting issues. I also tried to restart the converged solution with using pressure for indicator, but that still didn't make the boundary cells fully DG. I guess this issue cannot be solved separately and is linked to the resolution of the boundary layer. Do you have any other suggestions in this regard?
Noted. I am currently using posti_visu and exporting the data in a csv file from ParaView.
Thanks again!
Vachan
Simple Question regarding Heat Transfer cfd seeker CFX 9 June 22, 2021 10:19
heat transfer due to friction bemomb CFX 14 November 7, 2019 08:34
Underestimation of turbulence / heat transfer - Capillary tube Gadders FLUENT 4 December 10, 2015 11:31
Friction factor and heat transfer co-efficient manoj_1 Phoenics 1 May 4, 2011 13:36
How does FLUENT fair in absolute heat transfer analysis Steve Aboagye Main CFD Forum 1 August 31, 1998 13:12
