Source-Doublet panel potential derivatives
Old   July 11, 2022, 10:06
Default Source-Doublet panel potential derivatives
L.
lWiNdY is on a distinguished road
In a 3D panel method one computes the panel tangential velocities using the doublet strengths \mu as
q_l = \frac{d\mu}{d\l},
[LaTeX Error: Syntax error] in a local panel reference frame (see figure). However, how does one compute the derivative using finite differences?
That is in the case of a sphere there are triangular panels (see second and third figure) for which each panel is in a direction not parallel or orthogonal to the l-m-n coordinate system. What would be the tangential velocities in the l-m-n coordinate system?
1st figure : Katz & Plotkin, Low Speed Aerodynamics
2nd figure : Kirian Dixon, The Near Wake Structure of a
Vertical Axis Wind Turbine
lWiNdY is offline   Reply With Quote
Old   July 11, 2022, 10:09
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
You need to compute the superficial gradient using methods for unstructured grids. It is a vector that you can later project along any direction you might need
sbaffini is offline   Reply With Quote
Old   July 11, 2022, 10:21
L.
Do you have any pointers to literature on that topic?
Old   July 11, 2022, 10:27
sbaffini's Avatar
Paolo Lampitella
Nope, but I have seen a similar treatment for vortex rings. You can also give a look at apame to see how it does that
Old   August 3, 2022, 16:35
ichamail is on a distinguished road
Check the book COMPUTATIONAL FLUID DYNAMICS Principles and Applications by JIRI LAZEK.
Read the chapter 5.3.4 evaluation of the gradients (least squares approach).
At page 151
check eq 5.54 and 5.55
(rij · ∇)μi = μj − μi, where rij is the vector from i-th panel's control point to j-th panel's control point and μj, μi, are j-th and i-th panel's doublet strengths.
ichamail is offline   Reply With Quote
difference sheme, panel method
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
