July 8, 2022, 06:29 |
chtMultiRegionFoam not working
Mattia
Hello everyone. It's been a week since I started working on a multi region problem but the solver seems not to work properly.
1) I created a mesh using snappyHexMesh like tutorial "internalHeater". 2) I extruded in 2D the mesh I tried the case with zero velocity so to the only the conduction phenomena but between the regions the temperature seems not to be transported. This is the temperature in 0 file for fluid. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class volScalarField; location "0/fluid"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 320; boundaryField { minX { type fixedValue; value uniform 500; } maxX { type fixedValue; value uniform 500; } frontAndBack { type empty; } inlet { type fixedValue; value uniform 500; } outlet { type zeroGradient; } fluid_to_topSolid { type compressible::turbulentTemperatureRadCoupledMixed; Tnbr T; kappaMethod fluidThermo; value uniform 320; } fluid_to_middleSolid { type compressible::turbulentTemperatureRadCoupledMixed; Tnbr T; kappaMethod fluidThermo; value uniform 320; } fluid_to_bottomSolid { type compressible::turbulentTemperatureRadCoupledMixed; Tnbr T; kappaMethod fluidThermo; value uniform 320; } } This is the temperature for one of the solid in 0 folder: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class volScalarField; location "0/bottomSolid"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 500; boundaryField { maxX { type fixedValue; value uniform 500; } frontAndBack { type empty; } bottomSolid_to_fluid { type compressible::turbulentTemperatureRadCoupledMixed; Tnbr T; kappaMethod solidThermo; value uniform 500; } } // ************************************************** *********************** // All the constant in such are exaclty the same of the internalHeater tutorial, copied and pasted. Am I wrong in something here? |
chtmultiregionfoam, temperature |
chtMultiRegionFoam solver stops without any error | amol_patel | OpenFOAM Running, Solving & CFD | 4 | July 5, 2024 02:41 |
chtMultiRegionFoam connection between solid and fluid region of heat exchanger | ahab | OpenFOAM | 1 | December 18, 2019 01:37 |
Is there any institutions still working on solving N-S equations? | sharonyue | Main CFD Forum | 2 | November 11, 2015 09:23 |
what "If" condition means in rebound | brbbhatti | OpenFOAM Programming & Development | 0 | August 12, 2014 10:18 |
Simplifying chtMultiRegionFoam | miket | OpenFOAM Running, Solving & CFD | 0 | November 24, 2010 14:36 |
