July 7, 2022, 21:00 |
Streamline range of contour values
Zachary
How can I change the streamline range of contour values (show lower value streamline) so that we can see the circulation and vortex flow in the backward facing step? If possible can you provide a step by step guide. Thank you.
July 8, 2022, 04:44 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
In general, the negative values should define the recirculation region. Are solving the vorticity-streamfunction equations? |
[ANSYS Meshing] Accepted range of mesh metrics values for RANS (k-w SST) and LES simulations. | murali666 | ANSYS Meshing & Geometry | 3 | May 25, 2022 04:54 |
Two values for contour plots? | utsavac | FLUENT | 1 | May 26, 2017 23:12 |
Range of wall y+ values | rks171 | Main CFD Forum | 1 | January 4, 2012 17:54 |
particle parallel run crashes - values out of range | heavy_user | OpenFOAM Running, Solving & CFD | 0 | November 2, 2011 13:31 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 13:04 |
