Rep Power: 0 ![]() |
I ran multiple models (supersonic and subsonic) in PanAir to verify the results from published papers. I am getting Varied Coefficient of Pressure than that of the papers.
Procedure I use: 1.Create a model in catia. 2.Create planes and points on the model. 3.Extract the points. convert them to a .wgs format. 4.Create an auxilliary file for Panin convertor to get an input file to run in Panair. What am I doing wrong? |
Tosbaga
Rep Power: 9 ![]() |
Buddy, I've looked at your file, you are missing the wake panels for the wing. Without wake panels the solution you are getting is not physical.
Regards Last edited by Tosbaga; January 30, 2024 at 03:54. Reason: typo |
coefficient of pressure, panair, panel method |
How to evaluate aerodynamic performance using panair? | cfda | Main CFD Forum | 0 | March 5, 2019 21:58 |
PANAIR: PANEL METHOD CODE | Yogesh P | Main CFD Forum | 9 | October 26, 2015 18:04 |
Help! 3d hess smith panel method | zhongyu | Main CFD Forum | 18 | December 19, 2013 13:15 |
I am a beginner on PANAIR: Need of help! | la mimi | Main CFD Forum | 3 | February 16, 2007 21:37 |
PanAir software | Patrick van der Velde | Main CFD Forum | 3 | April 25, 2000 10:11 |
