June 28, 2022, 06:18 |
Scale down difference in results legends
haider ali
Rep Power: 15 |
Can anybody help me on this? Description= There is a rotating cylinder filled with gas and liquid is coming in from 6 static liquid nozzles. The liquid vof is 1 at the nozzle inlet. Problem facing: when I plot the liquid vof contour results, the contour does not show difference becuase there is significant difference bewteen the values in cylinder (vof= 0.004) and nozzle (vof =1), first image. I clipped the values manually in the contour legends to show the difference clearly, Figure 2. Is there any other reliable way to do it, since I am missing some values, Thanks Ali |
What to Do When There is a Large Scale Difference in Geometry? (too large/small dom.) | yanqoue | CFX | 13 | June 24, 2019 20:20 |
difference between turbulent Dissipative length and integral length scale | arun1994 | Main CFD Forum | 1 | August 1, 2018 14:26 |
The results difference between parallel and serial run. | Hkp | OpenFOAM Running, Solving & CFD | 2 | April 17, 2014 03:26 |
Difference in pressure drop results | To all fluent users need help pls | FLUENT | 4 | May 30, 2007 05:31 |
Difference in pressure drop results | al-jasim | FLUENT | 0 | May 28, 2007 10:54 |
