Fluent to Tecplot
Old   June 25, 2022, 20:28
Default Fluent to Tecplot
The_seeker is on a distinguished road
I am running some simulation on a plane channel geometry as shown in Fig. 1. However, when I exported the file into Tecplot, it shows a very wierd condensed sort of geometry as shown in Fig. 2. I never observed it before. Does anyone has idea about this issue?
Thanks in advance.
The_seeker is offline   Reply With Quote
Old   June 25, 2022, 20:29
Figure 1 did not get attached in previous message.
Old   June 27, 2022, 15:11
agd
agd is on a distinguished road
I would check to make sure that the XYZ axes are set to be dependent on the same factor (like 1). Tecplot likes to default 3D plots to weird ratios at times. Also, I assume that the "3D Cartesian" plot type is selected. If it's not either of those then the only other thing I have seen that creates issues like that is bad data in the file - either bad values or something that doesn't exactly follow the Tecplot file spec for whatever format you are trying to read in.
agd is offline   Reply With Quote
Old   June 27, 2022, 20:35
Thank you for your response. I managed to figure out the issue. I need to fix the scale factors. I adjusted the aspect ratio of X and Z to one which is what I need but I am not able to change the value of Y to 1 due to which the features in Y direction are shrunk relatively to what I have in Fluent. If I try to change, the number reverts back to 0.085824734. Any idea how I can change all three directions to one.
Thanks in advance.
Old   June 28, 2022, 00:21
agd
Try setting each of them to be independent.
Old   July 12, 2022, 23:55
Default respone
yes
janewalker is on a distinguished road
I appreciate your responding. I'd double-check that the XYZ axes are configured to depend on the same variable (like 1). Sometimes, Tecplot wants to default 3D graphs to odd ratios. Furthermore, I presumptively chose the "3D Cartesian" plot type. If neither of those is the problem, then the only other thing I've seen that can cause problems like that is bad data in the file, either wrong numbers or anything that doesn't exactly meet the Tecplot file specification for whatever format you're trying to read in heardle game
janewalker is offline   Reply With Quote
Exporting data from ANSYS Fluent to Tecplot 360 dbh0006 FLUENT 3 September 21, 2020 09:37
tecplot: read UDM variables from fluent data files denis.sanga@hotmail.it FLUENT 0 July 24, 2018 06:40
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 03:08
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 16:35
postprocessing Fluent Tecplot unknown FLUENT 0 October 11, 2009 07:34
