Why are my momentum residuals so low?
Old   June 24, 2022, 14:06
Smile Why are my momentum residuals so low?
sensitiveLook is on a distinguished road
I am running a simulation with ansys for flow in an aircraft intake. The flow is transient and when I setup FLUENT for getting the solution, the momentum residuals are very low like the x-velocity starts at 1e-10. And the same goes for y-velocity and z-velocity. Then they drop down to 1e-18, and restart from 1e-10 at the beginning of the time-step.
Can anyone tell me why mymomentum residuals so low?
As for settings:
Model: Detached Eddy simulation (RANS model SST k-omega with shielding function as IDDES)
Solver: PISO, 2nd order solvers for all variables,
Transient formulation: bounded second order implicit
Time-step size: 1e-04
Max no. of iteration/time steps=30
I have attached a picture of my residuals for reference
sensitiveLook is offline   Reply With Quote
Old   June 24, 2022, 14:49
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
We would need a crystall ball to tell. Could you share your velocity initialization and current field, cfl, etc.?
In general, the residual you see at the beginning of the subiterations, if I recall correctly, is still normalized with respect to the max res in the first 5 subiterations of the first time step. If your solution is changing very slowly, it might indeed happen that the following time steps all behave better than the first. But this is just speculation
sbaffini is offline   Reply With Quote
ansys, cfd simulation, fluent, residuals, transient analysis
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 15:38
motorBike Residuals for SST k-omega... and mine JR22 OpenFOAM Running, Solving & CFD 6 August 1, 2013 10:08
convergence at 0.5 momentum residuals hugocis Main CFD Forum 3 April 7, 2010 04:37
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
