Experimental Data Set for NACA0012 for high Re |
June 16, 2022, 05:08 |
Ravi Rana
Hi Everyone,
It's been two days, I am searching for a dedicated compilation of experimental results for NACA0012 airfoil for high Reynolds number (of the order of 6) to compare my computational result. If anyone is having any pdf or any web links, please share them. Your help will really be appreciated. Thank You ! Ravi Ph.D. Research Scholar IIT Madras |
June 17, 2022, 04:01 |
Chrowale
Rep Power: 5 |
I think I have seen it in the book "THEORY OF WING SECTIONS Including a Summary of Airfoil Data" by IRA H. ABBOTT and ALBERT E. VON DOENHOFF. I've checked the book just now there's the data for compressibility effect within Mach number 1+
June 29, 2022, 18:02 |
#3 | |
Lefteris
Rep Power: 16 |
Lefteris |
June 30, 2022, 04:17 |
Rep Power: 7 |
The following paper gives extensive data for NACA0012 at Re of order 6:
-Harris, C.D. Two-dimensional aerodynamic characteristics of the NACA 0012 aerofoil in the Langley 8 foot transonic pressure tunnel, Tech Rep NASA-TM-81927, NASA, USA, 1981. It is advised as the most accurate work when considering wind tunnel results for NACA0012 by Mccroskey: -Mccroskey, W.J. A critical assessment of wind tunnel results for the NACA 0012 aerofoil, Tech Rep, NASA-TM-100019, NASA, USA (1987). |
experimental data, high reynolds number |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 17:35 |
[OpenFOAM] Paraview python script, creating data using only CLI, saving in csv/excel file | Ash Kot | ParaView | 1 | September 24, 2021 13:23 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
How to set nonuniform T, U fields from point data | MisterX | OpenFOAM Running, Solving & CFD | 0 | November 28, 2012 09:38 |
How to assign the inlet B.C using a bunch of data set for an unsteady problem? | ali8500 | CFX | 3 | March 28, 2012 19:41 |
