Droplets doesn't break - Droplet generation process |
June 9, 2022, 07:06 |
Maximilian Fahland
I want to simulate a droplet generation process between water and oil. I have already validated surface tension, contact angle and inlet parameter. In the reality droplets are formed with this parameters. I'm using the VOF model with PISO solver. But unfortunately the droplets doesn't break. Is there an additional model which I need for the simulation of this droplet generation process or do you see other things which I have missed? Thanks in advance! |
droplets, piso, vof, water-oil |
Histogram on a selected volume, Droplet diameter profile | crevoise | STAR-CCM+ | 1 | December 8, 2024 17:54 |
Droplet break up at wire grid - multiphase model selection | mafych | Main CFD Forum | 0 | May 25, 2021 08:36 |
error 262144 and unexpected disconnect when run on 2 nodes | Emily1412 | SU2 Installation | 1 | April 10, 2014 18:08 |
Can I model the droplet transfer in GMAW process with FLUENT? | zsmhit | FLUENT | 0 | February 22, 2010 04:22 |
droplet impact on walls | zhzhguo | FLUENT | 0 | December 9, 2004 23:45 |
