Paper for boundary condition of turbulence intensity at inlet
Like Tree10Likes
Old   June 21, 2022, 11:32
Lucky
Did you think that you need to take the average velocity over the cross section or something?
At every boundary face, you need to take the local velocity and apply the formula. You are mapping a non-uniform velocity field, which means the velocity at every face is different. The velocity is not uniform and the k field is therefore not uniform.
Your issue is you don't know how to calculate k correctly and provide that list in the values, and so you plot the wrong things and it changes. The list of k at any iteration that isn't 0 is calculated correctly by OpenFOAM, which is your answer sheet to this problem! Whatever you do, you need to calculate k such that you get the same answer as the answer sheet. As soon as you calculate k correctly and put that list into the k file in the 0 directory, the k won't change anymore because it will be correct.
FluidKo likes this.
Old   June 26, 2022, 22:33
Thumbs up
  #22
FluidKo is on a distinguished road
Oh I got it.
I've just slightly confused because of my bad english level.
I'm going to calculate k for inlet boundary(control surface of mesh)
by using formula \frac{3}{2}(\overline{\left|U \right|}I_{T})^{2} and mapped velocity(uploade value).
Then I'm going to map this calculated k into 0 directiry.
After doing this I'm going to let you know ours following.
Thank you for your answer
FluidKo is offline   Reply With Quote
Old   June 27, 2022, 00:29
Lucky
Keep in mind you have to get the turbulence intensity from the previous simulation also. You need to calculate k from the mapped velocity and mapped turbulence intensity. And similarly for epsilon. Btw this is purely for academic purposes and a learning exercise.
As a best practice I still recommend you take map the k and epsilon fields from the previous simulation (just like you have mapped velocity). Because it doesn't just stop at velocity and turbulence; for any arbitrary number of transport models you might one day employ, you need to map everything over. For example... temperature and pressure...
FluidKo likes this.
boundary condition, inlet, turbulence intensity
Inlet boundary condition of turbulence Zhen ZHANG SU2 9 April 21, 2021 16:41
Fluent - incorrect inlet turbulence intensity (LES of a jet) jakub_ FLUENT 11 July 9, 2019 08:01
decay of turbulence intensity littlelz CFX 3 May 16, 2014 17:44
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? david39 OpenFOAM Running, Solving & CFD 6 February 2, 2011 04:01
High turbulence intensity wenfengxie FLUENT 1 April 16, 2010 13:00
