Node 3: Process 748: Received signal SIGSEGV. |
June 7, 2022, 20:27 |
Nima
Rep Power: 4 |
Hi all,
I have ran a simulation in steady state for 10000 iteration. Now I want to switch the method to transient from the last case and data that I have exported and simulate for some number of timesteps. (1500 timesteps, 0.0001 timestep size) I have done the change in the solver method, and autosave of case and data. Without any initialization, when I enter the settings for calculation, I get this error. Can anyone know what is the bug? Node 3: Process 748: Received signal SIGSEGV. ================================================== ============================ 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error 999999: mpt_accept: error: accept failed: No error ##the same line continues |
continue calculation, fluent, sigsegv |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 09:36 |
How do I change the serial udf to parallel? | dhdh89 | Fluent UDF and Scheme Programming | 14 | June 4, 2020 10:04 |
Process 10300: Received signal SIGSEGV | metaliat93 | FLUENT | 2 | January 28, 2020 01:53 |
Foam::error::printStack(Foam::Ostream&) with pimpleFoam of OF1612 on Cluster | shang | OpenFOAM Running, Solving & CFD | 7 | January 24, 2018 09:30 |
received a fatal signal (Segmentation fault) using udf to reading node coordinate | f.yn | FLUENT | 1 | July 28, 2017 16:55 |
