June 7, 2022, 13:28 |
ICEM correspondence with Meshing
Nima
Rep Power: 4 |
I have recently done meshing in ICEM and saved an export with some names. Then the solution ws finished and so on. Now I have opened "Fluent" to read the case and save it as a new case with slight changes. The question is I am not sure which .msh file was selected when importing to Fluent. I am going to delete some of the unused .msh files to gather some space for next solutions. * I am going to use a Cluster to run my simulations and Fluent launcher. |
June 7, 2022, 18:36 |
Sebastian Engel
Rep Power: 21 |
I haven't used fluent in a very long time. So i don't recall if there is a journal-log somewhere which could tell you what has been done to the file.
But as a workaround, i figure, how about using the absolute cell count of your mesh. these are likely not identical with your set of meshes. |
June 7, 2022, 19:45 |
#3 | |
Nima
Rep Power: 4 |
Regards |
.msh. case & data, export, fluent, icem, import mesh |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 10:16 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 18:08 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 11:09 |
ICEM meshing question | gsbhatia89 | ANSYS Meshing & Geometry | 5 | June 14, 2010 09:24 |
